Results 1 to 25 of 25
    Feb 2015
    United States
    Default Foot Brake Pedal Height Adjustment?
    I am wondering if there is an adjustment on the 'at rest' position of the foot brake pedal (right side, not parking brake)? The 2008 GS Sport riding position has my knees bent and my feet are too far behind me to allow me to raise just my toe to step on the brake pedal. The result is I have to raise my leg and foot completely off the peg each time I use the brake. The concern is the few seconds it takes to complete that action. Anyone have any ideas? Thanks.
    USA, Alabama, Leeds
    Quote Originally Posted by elkk View Post
    I have the same problem on my 2014 RT....... Dealer says no adjustment available. Any Mechanical gear head have a solution?
    Default NEED THIS INFO
    Do you want the surface of the pedal ...higher or lower ......I'll give you an answer depending .......Mike
    Feb 2015
    United States
    Lower TY
    Default OK
    Lower TY
    PM sent .........................Mike
    USA, Alabama, Leeds
    Lower please...... Thank you!
    Mar 2015
    Advance, NC
    I may take the foot lever off cut and weld it back where I want it. I can not rest my foot over the brake control with our flashing the brake lights. I want mine lower.
    Feb 2015
    United States
    Quote Originally Posted by Deer Slayer View Post
    Me too..damn stupid design. The foot shifter needs to be lowered too, I rotated the toe thingy down but still not low enough. Tomorrow I will pull the assembly off with a gear puller and rotate it CW one tooth or maybe 2 or 3, whatever is needed to make this thing enjoyable and safe.
    If I do cut the brake pedal I will bolt it back together and make it adjustable rather than weld it.
    Default LOWER
    Quote Originally Posted by ursamajor35126 View Post
    In my PM I suggested taking off the rubber cover and re-placing it with a piece of sheet metal......that's about a 1/4 inch, if you do this , before you put it on ,what I did was take a nail and put dimples in the metal then turn it over and bolt it on .......this will give you a traction surface and your foot will not slip in the rain......Mike
    Jul 2015
    Edmonton AB Canada
    Default Blueknight
    Could you post a photo of how you changed the brake pedal. Your solution doesn't sound like it would lower the pedal by a noticeable amount?
    thx
    Mike's solution is a good one...
    Be aware that if you lower the pedal too far; it will affect your ability to push it all the way down for maximum braking effort! It has a lot to do with the articulation of your ankle...
    Take small steps, and proceed carefully...
    Jul 2015
    Edmonton AB Canada
    Default Lowering brake pedal
    Thanks Bob. If I understand what Mike did I would expect a lowering of no more than 1/4 in. The ICIS brake lever extension would appear to lower it by an inch or so? So I assume there is a fair bit of "safety"'latitude? Maybe it is just the pictures are deceptive and isn't actually dropped much? I just can't understand how this idea makes a noticible change?
    May 2014
    Beaverton, Oregon
    Hi Gcclubs,
    Re: The ICIS brake lever extension would appear to lower it by an inch or so?
    If you are talking about this item #SPY-FB-BL: http://www.industrialspecialty.com/i...tm#brakelevers
    You decide where you want it located. You can drill the locator hole just about anywhere. But, be warned, it is a 'once & done' mistake.
    Jerry Baumchen
    Default HOUSTON WE HAVE A PROBLEM
    Quote Originally Posted by Gcclubs View Post
    thx
    Due to Bob D. .....My girlfriend and photographer is no longer my girlfriend .........so more PICS aren't going to happen....She already posted PICs of this check Her files....................I need to know if you have floorboards and if you have an RT or what ????.....You haven't supplied much info to help us out here.....Mike
    Jul 2015
    Edmonton AB Canada
    Default Lowering Brake
    I have a 2012 RSS se5. Not sure how to search for her photos as I don't know her name
    Default NAME
    ON THIS FORUM.......Deanna777+............................ You didn't say whether you had floorboards .....it makes a difference !!!!
    Mike,
    I'm sorry that you two are having trouble, and I do hope that you work it out...
    ...But I never mentioned you to her, in ANY conversation...
    Since you brought this to a public forum; I'll just say to look in the mirror for the source of the problem; it sure wasn't me.
    Active Member Ccol's Avatar
    Jan 2013
    Sunshine Coast QLD Australia
    This is how I lowered the height of the brake pedal on my 08 GS...
    Requires cutting off the original pedal and replacing it with a piece of 40mm +40mm +3mm angel ... drilling 2+6mm holes into the original brake arm to mount the angle (I drilled a second set of holes for adjustment if needed) .....
    I then drilled 2 holes through the other side of the angle to re mount the original brake pedal rubber...
    This dropped the pedal height by about 30mm...
    Mansfield Texas
    An ISCI Handbrake and problem solved.
    Jan 2019
    Alliston Ontario
    I just made my own hand brake. Not paying almost $1800 landed in Canadian. Did mine with a hydraulic front master and a small clutch cylinder and aluminum for about $150
    Mar 2019
    France
    Quote Originally Posted by MoDZuKi View Post
    Hi - could you post pictures PLEASE
    2009 GS SE5 , Red (Ferrari Red :) )
    Jan 2019
    Alliston Ontario
    I just posted details! and Youtube video.. Cheers
    Dave
    Mar 2019
    France
    Dave
    Can you post link PLEASE
    Mar 2019
    France
    Dave
    Found it great - would you supply kit????
    May 2019
    Manhattan
    Quote Originally Posted by Haikanko View Post
    HI great job with that brake set up I'm trying to do the same but I can't find the video on you tube can u send me the link please Thank you.
