Results 1 to 19 of 19
Thread: Ok to tie here?
    Jul 2015
    Wisconsin
    Default Ok to tie here?
    Trying to work with existing D rings in my trailer floor. Do you think it is OK to tie down to the bracket holding the saddle bag or to the passenger handrails?
    ps. For some reason the photo loaded upside down. Please stand on your head��
    RT-S PE#0031
    Jun 2009
    Snellville, GA USA
    I cannot speak to the strap point in your photos, but would strongly caution against using the passenger hand grips. The rubber coating will tear if you stress it too much. We've even seen reports where it tore when someone used a clamp style cup holder back there.
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    NO!
    Active Member JCGammack's Avatar
    USA, Iowa, Hayesville
    Default Tires-Tires-Tires
    Quote Originally Posted by Cognac View Post
    If you don't want damage to the bike, don't strap the bike. The tires are what touches mother earth (or trailer bed) so if you keep them from moving the bike will be fine. I would secure the front wheels then tension them by pulling back on the rear tire. I look at it as corralling the bike to keep it in the same area. If you try to tie it down so tight that something is going to break. In my experience what breaks is the load and not the straps. My goal would be to keep the bike from moving no more that an inch in any direction. That movement would not upset the weight distribution of the trailer and not break anything on the bike.
    Securing the wheels/tires also lets the rest of the bike use it's suspension to move as the trailer bounces down the road. Strapping to the bag mounts would put the suspension under load and all movement of the trailer is transferred to the bag mounts.
    There are various options and opinions on this but that is how I look at it.
    Chris Gammack
    You don't know what I don't know. I don't know what you don't know. All I can say is at my age what I don't know is huge.
    I call the Avatar "The first fifteen feet."
    Linden, CA
    I have a similar set up as you do and I am wondering why you don't use
    something strong like the frame or the trailer hitch to tie it down ?
    The bag mounts are thin tubing and will bend as will the grab handles
    Play it safe and use the frame.
    Ride Safe
    Dave
    Mar 2009
    Beavercreek, Ohio
    I lost my manual, but I believe it said to tie the wheels down and let the Spyder use it own suspension. Works for me. Just watch the straps are not in contact with a valve stem.
    Oldmanzues
    Nov 2012
    North Las Vegas, NV
    Yes, tie down through the wheels.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Bossier LoUiSiAna
    with larger 2inch wide straps if you can. Avoid stems & go UNDER belt. Dont just strap down but pull in oppisite directions<> (like tow trucks do)will be more secure. Dont trailer backwards where windshield will break in wind! Do not advise a cover that will flap in wind & scuff paint!
    Jul 2015
    Wisconsin
    Default Locked 'N Loaded
    We listened to all of your good advice. Trailer is too short to pull forward on the front wheels so we got chocks for them and then tied thru the back wheel with two straps, one pulling forward, down, and to the left and the other strap pulling forward, down and to right. Watching out for the valve stem.
    Tomorrow we'll hook the trailer onto our 26 ft. Lazy Daze RV and take a two week trip exploring upper Michigan. Should be tons of fun. And yes we could just drive the Spyder the whole way, but we love the RV, too.
    Thanks once again for all the help. You are so nice to us newbies. You folks are the best. Bless you. Bless you. Bless you.
    Jul 2015
    Wisconsin
    Default Last question on topic
    Once all tied in we closed the door to our enclosed trailer and found it right up against the hitch ball on the back of the Sypder. Is that ok? We put a protecting cover over the hitch.
    Default Hitch Ball
    I don't think that you would hurt the hitch ball. I would bet that any time you have any part of the trailer (wall, doors etc.) touching the bike expect that the finish will take a hit. Even with a cover (plastic or cloth) it will rub on that spot when under way. Any rubbing will hurt the finish. The only way to stop is to be sure there is an air gap between the bike and the trailer. This won't hurt the function of the hitch or ball but will rub the finish off.
    Chris Gammack
    Brookhaven, MS
    I strongly advise not to load and strap upside down as in this picture! ��
    RT-S PE#0031
    Jun 2009
    Snellville, GA USA
    Anything touching will wear. Likely just the paint at the point of contact. I don't know about the door.
    About strapping, you also have the option of strapping the front wheels, pulling to the rear and the rear wheel, pulling to the front. That would reduce the overall 'footprint' of your setup and may get you away from your door if you were to lose the chocks.
    Sep 2014
    3rd ROCK FROM THE SUN !
    its ok to strap a spyder like this.. but be real careful when you unstrap it... move out from under it VERY QUICKLY...or it prolly will hurt like heck when you do...
    osm
    Nov 2013
    Oro Valley Arizona
    Get a bigger trailer before you damage the Spyder. That's my advice.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Jul 2015
    Wisconsin
    We can uninstall the chocks and move them forward just enough for the hitch to clear the back door. Just an "Oh S..t" that can be fixed. Just needed a day to face the music.
    Bossier LoUiSiAna
    Quote Originally Posted by Orange Spyder Man View Post
    osm
    Funny you say that, parking like that was so EZ, all I did was post pic here.
    Aug 2012
    CO
    Strap the Spyder down via the wheels. Any tie point above the suspension will be stressed when the trailer goes over a bump and the springs compress/extend. The weight of the Spyder is enough to transmit that stress to the tie point. Think of it as constant jerking and tugging against one spot; eventually that will bend or crack. Also even if the Spyder is tightly secured it WILL move forward and backwards a little, so move it away from the door lest you want a hole in the ramp door over time.
    JLohPhotos
    2008 GS , Millennium Yellow
    Jul 2015
    Wisconsin
    Plan to use the wheel but just curious, what about using the hitch ball as a tie down point?
