Results 1 to 25 of 31
Thread: Battery Tender?
    Jun 2015
    Georgetown, KY
    Default Battery Tender?
    Hello all,
    Question, do you all only use a battery tender when you go extended times without riding? Like a week or two?
    What type of battery tender do you recommend?
    Thank you!
    Brighton, UK
    I use an optimate 4 that keeps it all topped up and has an inbuilt diagnostic. Really good product used them with all my two wheels before
    Free Thinking Member
    Apr 2009
    Southwest MI
    I do and I use the Deltran Battery Tender junior. I still have the original battery, it is over 6 years old.
    For the bigger battery in the RT the junior is not big enough. Get the full size version.
    http://www.amazon.com/Deltran-Batter...battery+tender
    The jury is out whether to plug the in when not being used regularly.
    Akspyderlady's sits for 4 days out of seven not being used. It is always ready to start up instantly.
    Once I determine I am done riding for the season, (black ice on the roads), I plug them both in until spring. Usually October - March.
    The rest of the time, I do not use the Tenders. Have been gone due to vacation up to 10 days with no ill effects on the battery.
    Electrical items that are not shut off or drawing power can have an effect on start up.
    Both of my 's are in a heated garage, so there are no cold weather effects on my batteries.
    western Colorado
    Quote Originally Posted by bobgeorge View Post
    Hello all,
    Thank you!
    nope! I use 1 maybe once a month on a Saturday when I'm not ryding. Use a extreme motorcycle charger.
    Jul 2013
    Stevenson, Maryland
    I use the Battery Tender Plus and I really only plug it in at the end of the ryding season... so it will sit all week, sometimes 2 weeks if the weather sucks... and she starts right up everytime!!
    Jonny
    Active Member STELLING MAN's Avatar
    Oct 2014
    Southern Ohio
    Default BATTERY TENDER
    I also use the Battery Tender Plus on my RT-S, It works great, but I only use It from Nov. to March..
    2013 Viper Red RT S-SE5 All 48 states on a Gold Wing now I'm working on getting all on a
    Default As I see it..!!
    extended periods of time are measured in months. If your battery will not hold for several weeks to a month or more it being drained or dying anyway....
    Apr 2014
    Beloit Kansas
    A week or two ???
    That's not an "extended" time. Now, if you're talking about bedding it
    down for winter... a matter of 2 or more months, certainly
    hook 'er up. An ounce of prevention and such.
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default Battery tender jr.
    All the time.
    it was fun while it lasted.
    Houston
    Always plug our bikes in when at home.
    Jun 2013
    Fleetwood, PA
    Battery Tender Jr. if it is going to sit more than a month. I have not had it plugged in since early April.
    NE Illinois
    I use the Battery Tender Junior and keep my RT plugged in when I'm not riding it. That's been my practice for years with other bikes as well, and I haven't been disappointed yet.
    MEP
    ​2019 F3 Limited
    Jan 2015
    southern WI
    Quote Originally Posted by mxz600 View Post
    I've got several of these around the house for the off-season periods of the toys.
    2016 RTS , Pearl White
    Active Member Raknid's Avatar
    Central NJ
    Have a BatteryTender Plus and a couple Juniors for the bikes. I plug the RT into whatever is free if not ridden for few days. The RT seems to have a very large vampire draw compared to our other bikes.
    2012 RT-SE5
    Jun 2015
    Georgetown, KY
    Thanks for all the wonderful info.
    Question. Where does the Tender get its power? Does it plus in?
    May 2011
    cincinnati, ohio
    Default Yep
    Wall outlet.
    Jun 2015
    Georgetown, KY
    Quote Originally Posted by coz View Post
    Wall outlet.
    Thanks, I thought so. That might be an issue. I live in a townhouse without a garage. Right now I just have the unit parked outside in one of my parking spots.
    western Colorado
    Ditto on townhouse. I just run extension cord out the front door.
    Jun 2015
    Georgetown, KY
    Quote Originally Posted by happyspyder2039 View Post
    And leave it out all night??
    Active Member Sccar's Avatar
    Mar 2015
    East Texas
    Default Battery Tender Plus
    I plug it in anytime I am not riding. I do the same thing for my car. Have done it on all my bikes
    2015 F3S SE6
    You don't stop riding because you get old, you get old because you stop riding
    2015 F3s , Orange/black
    Vermont
    Default Battery Tender JR
    I don't use the battery tender jr. during the riding season( April to Oct.) because I am usually riding. My spyder starts right up. I have a 2014RTS-SE6.
    I do use the Deltran battery tender jr. (12Volt switches automatically from charge to float!) when I put the in for it long winters nap ( from Oct. to April @ the dealership) the winters here in the NE are long.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Invalid Emails
    Jun 2015
    Plymouth, Vt.
    If you always use a battery tender, you can extend your battery life far beyond it's normal (untended) life expectancy. I used one on my Goldwing faithfully, and my battery lasted a bit more than six years.
    With today's electronics and computerized systems on our machines, there is a constant drain on the battery. If you have an AGM battery, it's extremely difficult if not impossible to recharge it if it's totally dead. For the $39.00 or so, I think that the battery tender is great insurance.
    Apr 2012
    Waynesboro, PA
    Do a google search. I believe I have seen solar powered units that are used on RV's
    Quote Originally Posted by 4 MARIE View Post
    A week or two ???
    The 1200 watt alternator on the 1330s does a bang-up job of keeping the battery charged.
    Example: When I had my 998; anytime that I plugged it into my Deltran 800, It'd show a yellow light for at least 20 minutes.
    My 1330 never showed yellow; only green.
    As an experiment this past Winter; I left it unplugged for two Months...
    I had a half-hour of yellow, and then right back to green.
