Doc's Spring Stiffeners - Easy install, low cost with excellent results. No more big nose dive BajaRon Sway Bar and Heim Joints - Really much easier to install than what you may think. Wow, I can't believe the difference it makes in the ride. No more "stuttering" when taking a corner hard and "normal" turns as well. SpyderPops Bump/Skid Plate - When you take it out of the package and compare to the OEM so called skid plate, you will start laughing at what BRP calls a skid plate. Very easy install Custom License Plate Frame - much cheaper than purchasing "Vanity State Plates".
Doc's Spring Stiffeners - Easy install, low cost with excellent results. No more big nose dive BajaRon Sway Bar and Heim Joints - Really much easier to install than what you may think. Wow, I can't believe the difference it makes in the ride. No more "stuttering" when taking a corner hard and "normal" turns as well. SpyderPops Bump/Skid Plate - When you take it out of the package and compare to the OEM so called skid plate, you will start laughing at what BRP calls a skid plate. Very easy install Custom License Plate Frame - much cheaper than purchasing "Vanity State Plates". Good job!
Current: "Scarlett", 2017 Can Am F3-T, SE6, Intense Red Pearl. BRP heated grips, DIY brake light strip and turn signal strips, Chrome/LED brake light tag frame, SpyderPops bumpskid, Baja Ron swaybar and billet links, Lamonster Third Peg, BRP Adjustable Passenger Backrest, SpyderPops Missing Belt Guard, ShowChrome oversize brake pedal, TricLED foglights.
Previous: "Synthia", 2014 Can Am Spyder RT, SM6, Pearl White.
Installed the Custom Dynamics RT GEN2 Magic Brake Light Flasher. My lovely assistant applied the brakes. One of my "boyz" Tater, had to be in the video too! He likes to photo bomb.
Good mods you did. And GREAT pictures of the mods. I don't think I've ever seen better pics of BajaRon's sway bar after it was installed.
Thank you,
I will be installing the BajaRon sway bar and heim links on my friends 2015 Yellow RT Limited Friday. Along with Spoderpop's Bump/Skid plate. I will be recording the install hopefully in detail.
