Testing the BajaRon 110 miles
I took the RTs for 110 miles on the very twisty route 33 and 47 in WV mainly to test out the new BajaRon anti-sway bar. Very little sway now. But there is still a tendency to "dart" back and forth". This is very minor and not a major concern...maybe just a characteristic of 3 wheelers. This may go away with more time in the saddle. We've only put 400 miles on her. I passed 4 other ( non Can Am ) trikes going the other way on todays ride.
BTW the left over bolts from the install are now back where they belong. Duh!
![Quote](images/misc/quote_icon.png) Originally Posted by SailnDive
The "darting" will go away in time, after you have gotten used to how sensitive the steering is. Just the slightest nudge on the handlebar one way or another will cause that. It took me awhle, but I finally learned to play the handlebar like a violin.![DG1](images/smilies/dg1.gif)
Pam
![Quote](images/misc/quote_icon.png) Originally Posted by Pampurrs
Pam
You hold it under your chin?!?
![](signaturepics/sigpic9193_3.gif)
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
![](https://www.spyderlovers.com/forums/maps/map.png?states=AZ.CA.CO.ID.MT.NV.NM.OR.SD.UT.WA.WY)
Great news..!!
We knew you would find the right place for those extras. The darting may also be your grip is still a bit tense. Your at about the average mileage to get really comfortable...
BajaRon Brace
The sway brace did great for me. A laser front end alignment did really great. I had my done at the 3,000 mile check. No shake and much better in curves. Very happy with BajaRon set up.
Tom s
dukeBlue48
It may be too much rider input causing the unwanted movement. It can also be an alignment issue. I highly recommend finding a good laser alignment purveyor. Most will not charge you if your Spyder is in spec. And if it isn't, then it is well worth the price to get the alignment. Pretty much a Win-Win situation.
If nothing else, it will eliminate the alignment aspect. Then any unwanted movement is definitely the operator.
Have a great riding season!
![](signaturepics/sigpic963_3.gif)
For those that are contemplating replacing their sway bar, I can only speak well for The BajaRon kit. Excellent components and instructions. It did take nearly 4 hours from the time I started getting everything together until I started it up to go on a test ride. A lot of that time was spent reading instructions, gathering up tools and figuring out where everything was located. It would take half that time now that I know how to do it.
I don't know what percentage of Spyder owners are changing this bar but you would think that CanAm would consider making this an option. It sure made a noticeable difference.
Keep a very light touch on the handlebars. It takes a while to learn.
As others have said, keep a loose grip. Keep in mind one tremendous difference between two wheels in front vs. one wheel is you have no gyroscopic effect to help keep the front wheel stable. On a two wheeler you would find it almost impossible to cause the bike to "dart" because the gyroscopic effect tends to prevent the wheel from turning side to side except by leaning. That's why you use counter steering on a two wheeler. With two wheels in front any quick push on the handlebar will cause the wheels to turn side to side.
![](signaturepics/sigpic14672_7.gif)
Make absolutely certain your tire pressures are up. There can be a world of difference in the stability of the handling.
