What's the deal with the back tire wearing out so fast?
I went on a 2700 mile trip and took my Spyder into the stealership to have the vibration problem looked at, and was told my rear tire was down to the wear bars. I said WHAT?! The bike only has 3100 miles on it! How could I need a new back tire?! I bought just over a month ago, and was trying to get 600 miles on it before I left for my trip. The guy at the dealer said they were pretty bad tires from the factory and a lot of riders are going to other tires. What I would like to know is what are some of you guys changing to, and how many miles are you getting out of them?
The "bad" tires were on 2014 models. BRP took care of that when they went back to the original compound. I wouldn't think your tire would be worn after that many miles. Have you looked at the tire? I would look at it myself before doing anything. Search for tire threads. There are a bunch of them.
If your issue is not the 2014 "soft tire compound" issue--then--your tires might not be inflated properly. Most use 28# in the rear tires.
I got 8,900 on my OEM 2014 RT tires. Now at 17K and the new ones are still looking good. (8,000 miles).
![](signaturepics/sigpic4721_5.gif)
Good post Gene. I forgot all about that.
Good advice......i made that same error with the RT tires.
2015 F3 (wife's)
2014 Indian Vintage
2019 AMG C43 cabrio
1966 LS1 Corvette restomod
1956 Corvette survivor (wife's)
1941 Chevy hotrod truck
2024 Corvette ERAY
WEAR BARS
Some stealers are clueless or worse.....there are two different levels of wear bars ......make sure they using the lowest set. And I highly recommend going to the General Altimax RT-43 in 215/60-15 size when you get a new tire....Mike
Something isn't right. I have a little over 3000 miles on my 2014 RT and the tires all look fine.
Maybe a naive question, but is it a tricky job changing the rear wheel on an F3?
![Quote](images/misc/quote_icon.png) Originally Posted by RedStar
Sounds like another dealer trying to make some extra bucks or a tech who doesn't know what he's talking about!
I have almost 3000 miles on my F3 and the rear tyre's fine. I ride fairly hard and give the rubber plenty to do!
I have no intention of putting a car tyre on my F3 as the bike isn't heavy enough to ensure that the tyre would work correctly.
The side wall won't flex enough with the light weight.
Tire Wear
Got 7800 on mine and looks like it will run another 7800 easy...F3S 2015
PERSONEL TO OJ
![Quote](images/misc/quote_icon.png) Originally Posted by OJ UK
OJ, Lamont is testing the new tire from V-rubber, and this may work out , we'll have to see..................However I have always switched to car tires and never had the problem some have had with the sidewall issue ......because I run mine at 21 lbs PSI.....not 28 .....I just went through some serious rain with my New Michelin Hydro-Edge, and I was impressed with it's performance in deep water............It dry performance is great also........just some thoughts ....Mike
![Quote](images/misc/quote_icon.png) Originally Posted by Chupaca
make sure they are talking about the wear bars and not the rain blocks. The rain blocks come up fast.....find the triangle on the tires edge and the wear bars are across from there...
![](http://www.spyderlovers.com/forums/attachment.php?attachmentid=111563&stc=1) all tires have these marks.... ![thumbup](images/smilies/thumbup.gif)
So if one were to get down on the floor to check his tire wear, what would he look for? Wear down to the "triangle" or colored marks across from the "triangle"?
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
OJ that is your choice not to use a car tire. Having used one for 12,000 miles I can say it does work correctly.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
The wear bar
In Gene's picture look below the triangle on your tire and you see the DOT information with an oval and some numbers, four, in it. Those numbers are the week and year of manufacture of the tire. For your F3 the number should be well later than 2814. Who knows! If it is not later than 2814 you got an old, soft compound tire and I personally would raise hell. JMO
![Quote](images/misc/quote_icon.png) Originally Posted by Highwayman2013
what car tire do you run?
![Quote](images/misc/quote_icon.png) Originally Posted by Martin Slovakia
Guys, so If i do understand this right..
The indicator marked in red circle - is something like information bar that tells me Be careful the tire is worn
The indicator in green circle - is an indicator that is tell you till when the tire is LEGALLY okie to still have it on bike..
am I right??
But anyway I dont see my tire to least 17.000km not even thinking about miles.. so maybe I am driving like idiot - but I dont do burnouts.. or maybe you guys drive like grandpa-s??? ![Smile](images/smilies/smile.png) -just joke no offense.. ![Smile](images/smilies/smile.png) ))
![](http://www.spyderlovers.com/forums/attachment.php?attachmentid=113044&stc=1)
I think they get a bit carried away with the wear indicators on tyres...remember they are selling them, the higher the indicator the quicker you say , **** tyres are getting low, I better get another set. More coin for them
Ozzie Ozzie Ozzie
Great info....and to add, the triangular on the side is your sidewall wear indicator. You should not scrub into that triangle basically. (Super low tire pressure and turns will have the sidewall flexing into that triangle)
Yep.. BRP installed "defective substandard" tires on the 2014 spyders .. but they won't back up their screw up.. so after buying a $30,000 machine you have to go out and buy a "real tire" to replacement a goof up... buy anything but a 2 ply junky Kenda... save yourself some money and go to a regular tire dealer .. they will install it if you take the rim off your spyder..
osm
alternative
I want to buy some alternative. Peter gave me some advices but because i am from CEE Europe and summer time is almost over and the dimensions are bit unusual, I have small problem to find a good one still available.
options are:
1 - Toyo Prexes T1-R - not sure about the top quality.. price about 100Eur
2 - Toyo Proxes R888 - but they are bit pricy, and I think more suitable for tracks that for roads...
3 - Kumho 225/50/15 - ECSTA ASC - there is only one seller at my region of these tires and seem not really helpful guy
4 - NEXEN CP 641 - never heard about them
5 - Advan by Yokohama are not available - but they look like badass
any idea about different good brands.. maybe I am searching wrong....
Rear tire
I have Kuhmo's on mine and replaced at 32,000 miles, I now have 51xxx on the bike and just recently put on a new tire. I keep them on as they seem to last longer than anything BRP has. Am not too sure about "car" tires for the front. If the front is aligned correctly they last a long time ( the ones I have are the BRP ones.) misalignment can REALLY mess up your day and replacement can happen every 6000 miles. Now that I have the front correct the tires have been good for over 8000+ miles and still looking good.
