There is no need for $500 wheel chocks. A set of good quality ratcheting straps tying down the wheels correctly works fine, is the BRP preferred method, does not damage wheels, alignment or any suspension component. I have hauled vehicles FAR in excess of 10x the value of spyders many thousands of miles using ratchet straps through the wheels and never once damaged a wheel or suspension component. The wheels and thier attachment are what supports all forces on the bike during normal road use, they are the only parts designed to do so and are what should be used during transport.
Mike's suggestion of an over the tire use of the strap is a good one and works well on trailers that have access directly in line with the tires. Many trailers do not.
Sorry to say, superclamps are a well built solution looking for a problem that does not exist.
Thank you JC for your comment, it seems like you , me, and a very few others get it......But you doubters and naysayers consider this ...." U-HAUL " one of if not the largest mover of things in this country uses exactly the same RACHET STRAP DEVICE on the car dollies they rent for exactly the same reasons I do....go to their web site and see how they tell the renters to secure their cars to the dollies.....and if you are scratching your head wondering what I'm talking about .....start at the beginning of this THREAD and read all the posts........Happy Trailering. Mike
This is no BS....I've trailered and trucked to Spyderfest twice 3000 miles round trip each time. The only tie-down I have used was a single Heavy Duty Rachet strap put over the rear tire ( in line with the tire ) , with the strap secured in the front and back of the rear tire. I lower the tire pressure by 1/2 and rachet it tight. I was in a serious accident and the Spyder never moved ......That Strap cost me about $5.00......Nothing touches the paint , nothing can bend and suspension parts etc. and it takes me about 10 minutes or less to secure. I rarely have to add tension............You can spend a lot more but the Spyder won't be any better secured.......You can't spend any less............Mike
Mike,
Do you have photo showing the rear tire secured by a single strap that secure both front & rear motion? I can visualize the single strap securing front motion, but the rear motion--not so much ???? Is the F3 parked with the front facing the front ? I have several motorcycle wheel chocks but all are too narrow for the F3 wide rear tire..
Thanks,
d
Mike,
Thanks,
d
Type this in exactly......THE EASIEST.....It will be about 15 down in the list.......Mine is in a home made cradle, but that is because that is what I needed.....All anyone has to do is secure the front hook in front of the tire somehow.....and the rachet has to attach at the rear of the tire somehow......And that's it................I had a fairly serious collision and the Spyder never moved.......Some people just believe the expensive and /or complicated something ....it just has to be way better.....BS...........I have no complaints with the SUPERCLAMP, I'm sure it works as stated by the manufacturer.......but it does cost over $ 400 more than mine......If that rows your boat great.....it doesn't row mine..........Mike
Tie down---secure rear wheel with heavy duty strap. Secure front wheel chocks(front side) with small bolts to trailer--after parking Spyder on trailer slide the (rear side) chock behind the front wheels. Rear side of front wheel chocks could be secured with a removeable pin.
These 2 piece chocks sold for $6.95 per wheel.
d
Reason: spelling error
The price is certainly attractive, however let play devil's advocate ......say you hit a medium bump or pot hole ....trailers have notoriously bad suspensions......I wouldn't want my Spyder counting on 4 or even six of those .......My $5.00 Rachet strap over the rear wheel works....I know this for a fact.....it's been accident tested.......Mike
Superclamp is the vendor so it is expected that he will extoll the virtues of his product. I would too.
The strap over the back tire makes sense to me. Is there a way to put 2 straps directly over the rear tire? I hate the thought of a single point of failure!
RTDillon1960, I am pretty sure that Nyparrothead already transported his bike at least a month ago. What was the point of your post? All it did was rile people up. Why?
I asked the question because I just purchased a F3S and will be hauling it. Given my engineering background I do not like a single point of failure in any system and would like to know if 2 straps on the back tire makes sense. I really like the hold down system in the pictures and expect to use a variation on that...across the back tire.
The only person riled appears to be you. Does that explanation meet with your approval? Do I have your permission to continue this conversation with folks that have been there and done this?
Being an engineer as well and well versed in the belt AND suspenders routine, we tie down all three wheels on each of our spyders when we transport them. Total of 4 ratchet straps for the 2 bikes.
The small chocks are a good idea and cost effective to prevent rolling, but you still need to tie the bike down.
Anyone else remember that tune ?? or where I left my cell phone, car keys ???
I thought I mentioned securing rear wheel along with $6.95/wheel chocks
Inexpensive front wheel chocks
In 2013( at the time I had a 2012RTS-SE5) my spyder was on a sled trailer and it was tied down with a Ratchet strap. The ratchet strap was over the center of the rear wheel and underneath the spyder( the ratchet strap did not scratch the tupperware) and secured to the front of the sled trailer.
I can vouch for Mike -blueknight911 my spyder ( 2012RTS-SE5 at the time) did not move in the accident that we had. Sorry no pictures.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
SpyderF3, Did you customize the strap that's on the ratchet to make it longer or did it come long enough to be in front of the tire like that?
Try DISCOUNTRAMPS.COM ……… They sell on E-bay at reduced prices and Free shipping ……… Lots of choices for length and they have some/most rated at 3500 lbs +...……… way overkill, but good peace of mind ……………………...Mike
It came long enough.
The one end with the ratchet was just the right length to hook in the E-track around the back of the tire and come around the tire to the front, then I cut the excess strap from the other end that hooks in the E-track in the front. I really didn't have to cut the strap but I didn't want to have to deal with all the extra strap all the time.
nice set up but why not one on rear tire too? As most flat surface vehicle tows require pulling the vehicle from front & back preventing additional movement. Just a thought
It looks like the 2"x12' strap at Discount Ramps has that longer tail on the ratchet. I'm going to order them so I don't have to mess with that floppy roller thingy at the back of my tires. Thanks SpyderF3 and Mike.
2015 RTS Special Series
Russell Day Long seat
F4 Customs windshield
Sena 20s
