![Quote](images/misc/quote_icon.png) Originally Posted by Biggdogg22
Hey Dr... Where did you find the Digital Oil Pressure Gauge & Volt Meter? Once installed, Did your fuel gauge show up in the digital display window automatically or did you have to make some adjustments? Thanks, Reggie
Gauges came from http://prosportgauges.com/. You will also need the T connector to install the oil pressure.
Here is the tee you need:
Company name British American Transfer Inc.
Phone number (941)355-0005
Part number TPVW gauge tee 10MM x 1.0 $12.50
Some have screwed the 10mm male in to the block, screw the oil line with compression fitting from the gauge into the 1/8" NPT in the side and the stock warning light sender into the 10 mm female and done. Some have also had high pressure hoses made with 10mm male in one end and 10mm femail on the other to mount the 'T' elsewhere so it is not hanging directly from the engine block. I had a 18" hose made. Search the forum for more info on the oil pressure mods.
When you disconnect the factory gauges, the digital 'gas' and 'temp' come on the multi-function display. You must disconnect both for it to work.
Reason: Spelling
![Quote](images/misc/quote_icon.png) Originally Posted by Doktor
I'm planning on adding a Yaesu FTM-10 to my RT-S also, what kind of antenna did you use? Looking at the rear of your bike I don't see any exposed antenna at all, or are you just using for it's bluetooth/am/fm?
Doc
After a few tries I found that only a 1/2 wave would work due to no ground plane. I used the Diamond HRKS stick on mount trimed down and stuck over the unused antenna mount location with the wire feeding into the opening. To make sure it stayed put I put some of the 3M tape activator on first. You can adjust the antenna angle to match the factory radio antenna. Had it off at the time of the photos. I'll post updates in the next couple days.
Great job, DR Buck!
Great job, DR Buck! And thanks for sharing your pictures with everyone.
The boards / highway peg setup you have is absolutely amazing. Good work
Ok how did you wire the ptt button into the ham radio. I've been looking into doing this to mine.
I have a 2012 RTS. No CB radio installed. Thanks KG5CFK
Doc
With the air filter kit, has your gas mileage increased since your install? Also, Has the CAT Bypass made anything significantly different?
Reg
With the air filter kit, has your gas mileage increased since your inI'm not sureall? Also, Has the CAT Bypass made anything significantly different?
Reg
Removing CAT gets rid of excess weight and LOTS of unneeded heat. I get about 25 to 27 MPG. I'm not sure what gave the most improvement as I did it all for improving airflow and getting rid of heat. MPG has never concerned me.
Mod Monster
All... VERY nicely done Mr. Buck! Quality work.
____________________________
Phil - Tyler Texas
2010 RT-Premiere Edition (Named DARTH) | Timeless Black | All My Mods--- ARE HERE | Phil. 4:4
What does the parking brake fix do?
![Quote](images/misc/quote_icon.png) Originally Posted by Mexrider
Keeps the cable from popping of the motor pulley. There were several different ideas guys came up with. The most common was drill a hole through the pulley and add a tie-wrap.
all I can say is "WOW"
nicely done!
