Results 1 to 6 of 6
    Mar 2022
    VA
    Default How do I jump start a 2020 RT - need basic level instruction/vids?
    Bike has been sitting since July.. god damn mice found inside the front trunk… Won’t crank. Hoping I can just jump start it.
    I’ve searched and can’t find any updates videos on how to do this? All videos I’ve seen are for 2012-13 models!
    Last edited by Peter Aawen; 01-10-2023 at 04:02 PM. Reason: Expanded title to briefly ask the question as amended in later post... ;-)
    Harrington, Australia
    Quote Originally Posted by ScottnSuzyQ View Post
    Just to make replies a bit easier, Scott&Suzy, how deep do you need to go? I.e. Do you know where the battery is and how to get to it? Do you have a power pack and cables, or does the jump have to be done from another vehicle?
    HeliBars Handlebars
    Kenda Kanine rear.
    Feb 2020
    Minnesota,USA
    Also, ChecK KILL Switch and Mode Button! One sometimes tends too forget after a period of time.
    10W40 Amsoil Synthetic Motorcycle oil
    If in Doubt, Don't Do It!
    Mar 2022
    VA
    Sadly I need the someone to break it down Barney style! I don’t have any fancy packs. I may have to just buy a new battery? I would end up having to jump it with my diesel truck. Can someone post a video of where the battery is located and how to get to it? I see the fuse box inside the front trunk…
    Springfield, MO
    This might help. I just made this video yesterday.
    https://www.youtube.com/watch?v=7L6G2yLougw
    KISS - IMHO start with the least expensive option ..... Take jumper cables - connect to car or trk battery ( correctly ) leave veh ... OFF connect the Spyder battery .... try to start it .... if this fails, make sure you actually have current flowing thru the system, does it even try to start ???? .... if yes have battery LOAD - TESTED ( it's free at most auto parts stores ) let us know what happened .... Mike
Tags for this Thread
