Results 1 to 25 of 25
    Nov 2019
    Kansas
    Default Just bought the Dynojet PV3 for my 18 F3L
    I am so excited about this. I hope it really makes a big difference when it is all done.
    I can hope.
    Sep 2014
    USA
    You will feel some difference , but if you were looking for that big difference it will not be there.
    Feb 2019
    Portland, Oregon
    If you really wanted to feel difference, you should have gone the Pedal Commander. The nice thing about the PC is it is adjustable from mild to wild. Plug and play too.
    Sep 2020
    Middletown, NJ
    If you're a spirited rider, you notice the acceleration boost. If you're 'normal', you may not sense the added power. Add the PC and hold on tight!
    2020 RT base , Chalk White
    Active Member 308gunner's Avatar
    Oct 2017
    covina california
    you will notice a big Horsepower/Torque difference...especially getting on and riding on the freeway..passing 18 wheelers etc...riding with a fully loaded trailer and passenger..your motor is no longer running lean on fuel due to C.A.R.B. restrictions. now your bike will run the way its supposed to be from the factory....you made a very smart move by purchasing one...when you install it..please post a review.
    Nov 2019
    Kansas
    I did this saturday and it is a massive difference with torque, etc. it has a lot more get up and go. Way worth the price I paid
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    Quote Originally Posted by acdcking12 View Post
    Can you rate the difficulty of the job?
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    Mar 2017
    PC is not for me. All it does is change the throttle position sensor to "already on." Say to get the stock acceleration normally you twist the throttle from 0° for none to 90° for full acceleration. With the PC on the "wild" setting, twisting the throttle 30° tells the TPS you've twisted it 90° which IMHO is dangerous. Twisting the throttle any more than that 30° will just be dead net zero gain cuz the bike thinks the throttle is already at max. If you like riding at full throttle all the time, just do that - twist a bit more which gives you more control over your bike. You gain nothing with the PC.
    Sep 2020
    Middletown, NJ
    Quote Originally Posted by Rattlebars View Post
    Clearly, you either haven't used a PC or you're not the type rider that would benefit from the change in response the PC offers. For one thing, you assume we all crank the PC to full (Sport+). There are many steps of sensitivity ranging from ECO, City, Sport, & Sport+ with steps in between. Personally, I usually have mine set for Sport when riding spirited in the twisties. It absolutely increases my corner exits. That, combined with the PV3 tune, will keep up with most 2 wheel sport-tourers.
    Nov 2019
    Kansas
    Quote Originally Posted by ButterSmooth View Post
    Really easy and I am not mechanically inclined. Took an hour. And that was mostly deleting and re writing to the computer.
    Sep 2020
    Middletown, NJ
    The installation of the PV3 is: 1 plug the PV3 into the OBD connector under the grill, 2 follow simple directions to extract your current OEM tune, 3 upload that file to computer and go online to upload it to tune provider, 4 download the new tune, 5 flash the new tune into ECU, DONE! Each of these steps are well documented and very simple.
    You can go back and forth between different tune files depending on your needs since the PV3 stores 4 tune files - including your OEM tune if you need to revert back.
    Sep 2020
    Central Oregon
    Is there a preferred vendor? To those who've got 'em, where did you get yours? Why does Fuel Moto not list the RT as an available fitment? I see F3s listed in some offerings, but not RTs.
    Spyder Tryke Pylot
    Sep 2020
    Middletown, NJ
    Fuel Moto didn't offer the PV3 on their website so I bought directly from DynoJet. The 1330 engine in the RT is the same as the F3. I suppose if you contact Fuel Moto, they will sell you the PV3 including a better tune package than DynoJet.
    Feb 2019
    Tampa, Florida
    i just bought the PV3. I hooked it up to the diagnostic port, turned key on, nothing. Plugged in the supplied USB for power. Screen says to connect to ECU, it's already connected! I tried multiple times and wiggled the wires, even started the the Spyder F3 Limited. Nothing! Anyone have this issue? Could I have bad PV3 or cable? I've emailed the tech support but it's Thanksgiving day and no one is there. Might have to wait until Monday.
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    HEY SKUPS, You do not use the usb power cord while it's plugged into your Spyder.
    Make sure your plug is seated all the way in to the spyder diagnostic plug
    T.P.
    Feb 2019
    Tampa, Florida
    Well, in the instructions it says if the PV3 doesn't power up from the diagnostic port, use the USB. I also noticed on the plug of the diagnostic, there is a red wire, which is usually a power wire. On the pin configuration of the PV3 plug, it doesn't line up with that port. I'm wondering if I got the wrong cable. I've pushed the plugs in tight, made sure it's clicked in, wiggled and jiggled, nothing. BTW, currently Dynojet is doing a sale of $40 off the usual price, I unfortunately didn't didn't get that deal cause I ordered it about 2 weeks ago, missed the sale.
    SoFlo
    Quote Originally Posted by Skups View Post
    So then, are these currently on sale at Dynojet, or is the discount from other vendors also?
    Feb 2019
    Tampa, Florida
    Currently on sale through Dynojet.
    Aug 2020
    Lake Sam Rayburn Texas
    I had a similar experience. When you contact them, they will send you an adapter cable. Mine worked with the adapter.
    Aug 2019
    Stoughton, WI
    Also on sale at Fuel Moto.
    2022 RT Sea To Sky
    Feb 2019
    Tampa, Florida
    Looks like I need the adapter also. They're sending me one.
    Nov 2019
    Kansas
    I needed the adapter for mine too. But mine came with it.
    Oct 2017
    covina california
    Did you ever get the new cable and try to install it?
    Nov 2018
    Tonopah, AZ
    Pedal Commander only changes the Throttle position relative to the Throttle Body, no A/F ratios or timing curves
    2018 F3 Limited , Stock Doc Humphrys Intense Red
    Nov 2018
    Tonopah, AZ
    If you have a PV3 you dont need a PC, you can adjust the throttle to throttle body ratio in your PV3 tunes.
    I do not have a PV3 on my spyder yet but had one on my Indian.
