Page 1 of 78 123451151 ... LastLast
Results 1 to 25 of 1945
    Jan 2015
    southern WI
    Default What did you do to your Spyder today?
    Just what it says really...I see this question/topic on a couple other forums I visit, and it's always interesting to see what people post. So, what did you do to your Spyder today? Any model, heck let's include Ryker too.....
    2016 RTS , Pearl White
    Mar 2015
    forrest above Reno, Nv
    Checked out the new tires ( Quadtrak 5 ) up and down Gieger Grade. They work REAL good. 17.5 psi BTW.
    Lew L
    2014 RTS , Circuit Yellow
    Mar 2013
    Picked up gas to top off the tank for the winter storage and received a K&N air filter to put in. This will complete my maintance work which was new spark plugs, oil and filter change, transmission filter replaced, gas filter changed, and sea foam added to the gas tank, battery tender hooked up.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Jacksonville
    Glad you were able to include Ryker - road it and had fun - as I do every day!!!!
    Active Member MonPaul's Avatar
    Feb 2019
    Central WI
    Since we have snow here already, I winterized it and stored it away over the weekend.
    So all I did today was go out to the garage to see if it was still there.
    Nov 2017
    San Francisco Bay area
    Night ride to my Scout Troop meeting and back home.
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    2015 RTL , Yes Pearl White
    Oct 2015
    Lynden, WA
    Sat at my desk at work and daydreamed about riding.
    At lunch time I did some research for front tires for the ST.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Feb 2012
    Spring City,Utah
    Wished I was riding instead of driving, then found out I have Dr.'s appointment in the morning so I will be riding at least one more day. No new snow here or for several more days so I may get some more riding in.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    INDIANA, USA
    Default 59°
    I took my Spyder for the afternoon 'wind therapy'......
    ENJOY YOUR LIFE WITH A SPYDER
    Durham,Maine
    took it for a spin up the road to see why the power was off, and see when it was going to be back on!!
    2012 RTL , Pearl
    Aug 2008
    MA & NH
    Nice medium ride, little cool. Got some gas and called it a day. Content.
    SoFlo
    Last week, Not today, I spent some quality time working on the Spyder. I had a stash of parts that had accumulated but not been installed.
    The mods from last week were.
    1) Replaced the oem spark plugs with Nippon Denso plugs
    2) Converted the Spyder and RT622 trailer from 4 pin square to 4 pin flat.
    3) Replaced the oem cast aluminum windscreen arm with the NoBoot billet aluminum windscreen arm.
    4) Installed 1/4 turn fasteners to the left and right bodypanels to prevent them from inadvertently jettisoning while moving.
    5) Removed more of the soundproofing foam and adhesive that had turned to goo with age. At this time I have not replaced the soundproofing, but will, utilizing the same high performance material we use in aircraft, and I already replaced on the Spyders acoustic panels.
    6) Flushed the brake system, bled and serviced with new Pentisone fluid.
    7) Replaced the fuel filter, utilizing fuel injection specific hose clamps.
    Feb 2012
    Spring City,Utah
    Wow I am listening to the weather on the news and she just said to take the bike today cause the weather will be great. I think I'll take her advise
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    We try to get between 50 to 100 miles in most every day, now that we are in the South. Yesterday, it was 60's and sunny. Today, high 50's and some clouds. Perhaps a ride this PM.
    I am not planning on a winter lay up. Time will tell. The bikes were serviced a couple thousand miles ago...so we are still good there.
    Like most days, rode it to the gym to work out only it was quite nippy with some frost in spots so I made the routine 13 miler one way a 25 miler to get it fully warmed up. Reversed it on the way home.
    PA
    I said “Gooooooood morning Bella!” this morning as I walked by her and I pulled out of the garage in my truck. She smiled and went back to bed. Her dumb brothers smiled too, like a bird dog when they see you dressed in orange. IT’S SNOWING TODAY! Yep all three sleds Look like dumb dogs sitting behind her. Suppose to be in the 40’s and sunny Saturday. She’ll get a little Jolt and ride then.
    PA
    Snows gone today and its partly sunny at 32 degrees and dry roads so.......”I road her to work.” The 3 sleds did not look happy when I closed the garage door! Just warming up for sledding season. 4-6” snow tomorrow -Friday but Saturday is looking good suppose to get into the 40’s and sunny again! 18 miles to work and 18-30 miles home depending on the detour
    I finally decided that the weather had turned against me. I used to ride my GW down to 32-24 degree's , but that was when I was young and had something to prove. I'm 72 and only do things if they are fun. So today, I cleared up the mess in my basement fully heated the engine ( 4 bars ) and brought Her down ( 5ft below ground level ) to the Spydercave. I put Her up on ramps and jacked up the rear 12 in. took off the drain plugs and removed the oil filter...…. 6hrs later it is still dripping oil, ( might as well get it ALL out )… Aftyer removing the right side mirror ( I have magnets so very easy ) I removed the upper side panel. Last year I drilled a large hole in the inside panel, so I could extract the oil filter without having to remove that panel. I haven't noticed any more heat on that side so I won't be covering the hole, ( it could be done with Duct Tape ) ….. I'll post a pic of where to cut the hole if you want to see where it's done …… Mike
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    My bike finally arrived last week and is currently undergoing a transformation from a Dark model to a chrome model with a ton of extras being put on.
    Soon it will be done and sitting in my garage instead of the dealers.
    2022 RT Limited , Silver w/ Black and Purple accents
    Jan 2015
    southern WI
    Another 3" of snow here today so we're stickin a fork in it for the season. Oil is changed and they're tucked away in the corner.
    Active Member ozarkryder's Avatar
    Nov 2018
    Anderson Missouri
    Always put the bikes away for the winter as soon as salt went down on the roads when we were in Minnesota, latest I ever rode was the day after Thanksgiving. Since moving to the SW corner of Missouri I detail the bikes, change oils, fill with non-ethanol gas, add fuel stabilizer and run them to get the stabilizer into the engine. Did that today. If the roads haven't been salted or if the salt has been washed off by rain I'll ride all during winter, and fill with ethanol free gas and stabilizer after the ride before garaging the bike again. I also did a complete tire deflate and change over to winter air.
    2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
    Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
    2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
    Mar 2018
    north georgia
    after checking the weather which is calling for rain tomorrow, i thought i had better ride today, very nice upper 60's very sunny in the north Ga. mountains so 135 miles later i changed my fender tip lights after noticing both were not burning. i installed led's last week and both were broken, base's were still in but led element broken on both, both were working when i left home, so i put the originals back for now, I'm at a loss as to how both were broken
    Jan 2019
    Hunter Valley NSW Australia
    Not specifically today but over the weekend removed the BRP shocks front and rear and fitted Wilbers shocks. Not a fun activity but done. Test ride Sunday on my 250k m test track of highways and country back roads found a few problems
    1. Cant stop grinning at how much better the 17 RTL is to ride, this isn't an incremental improvement but a huge one. As soon as I reversed out of the garage over a small ledge in the concrete, I could feel the difference in the way the shocks behaved.
    2. Because the new shocks are finally doing what suspension is supposed to, I cant stop looking down at the front wheels hugging the road.
    3. To finally have the ability to adjust compression and rebound settings is right up there with holding an overly full bladder for 10 hrs and finally getting to wee
    4. I have not played with any settings (seems a contradiction I know from the above comment) because the calibration by Wilbers based on my weight and riding prefs is spot on. This will change when my copilot comes for a ride who's weight has been factored in too
    They are pronounced as Wilbers - but you should pronounce the same way Homer Simpson pronounces Doughnuts - that mesmerized tone he uses.
    2017 RTL , White
    SoFlo
    Quote Originally Posted by askitee View Post
    An awesome what did you do to the Spyder reply. FWIW, you will likely find that once set, the clickers will stay in that setting without a need to change.
    Sebring, FL
    Not being familiar, the two pics are different. Can you explain? Thanks.
