Continuing DESS Issue?
Hi, been reading ours an hours of threads regarding the DESS and key Error problems. Is this an issue still continuing? I have a 2014 spider and it appears these issues started then. Can I be comfortable buying a brand new spider that I will not have this issue?
![Quote](images/misc/quote_icon.png) Originally Posted by w6ada
From what I've read on the DESS issue, yes they started with the 14 model …. BRP changed them 3 times, trying to FIX it …. the last version seems to have worked ( for the most part ) …. however they still have failures at least thru 2017 model ….. as I told you in a PM , a few folks here have the BUDS program that will cancel / eliminate the DESS module..... I have not heard of a DEALER that will do it …… If your Spyder is out of warranty - the module costs around $ 135.00 ( cheapcycleparts.com ) and can be changed by most DIY'ers …. the module is located behind the frunk - bolted to the firewall just above the Battery …. it unplugs ( two ) …. As I told you ( in PM ) I then put mine under the right headlight ( the wires will reach that area ) and you will have instant access to the module and plugs...…. IF you have seen the " ORANGE " screen of death , your Module is now in failure mode and will eventually DIE, ……. Mike
New or used....
The new models sold should all have been updated. If you look into a used model always a good idea to have the dealer check the vin# and see if all updates have been made. We see very little here as of late but we only see those that post here and there are many more out there. I would not let this keep you from getting one...
I believe they have it worked out, or I wouldn't have traded my 2014
Yes well I am at the screen of death. I needed a post in order to be able to PM you. Personal message come in later today. Thanks for all your help
Huh ... the things I'm finding out about my new ride! Wow ... any other hidden gremlins I should know about before our week long trip at the end of June?!? We'd sure hate to get stranded for something simple to fix like moving the trike and turning the key 5x's.
Just drive and enjoy the Spyder. That's even if you get the DESS message.
![Quote](images/misc/quote_icon.png) Originally Posted by Sarge
New to the Spyder community. What is this "DESS"? And what is this "Orange Death Screen". Mine is a 2015 RTL. What's all this about please.
![don't know](images/smilies/shrug.gif)
Thanks in advance!
HI,
D.E.S.S stands for Digially encoded Security System.
I have a 2014 RTS-SE 6 and I have had the D.E.S.S module replaced 2 twice in 2015 ( under the warranty,) and the Switch( in 2015) replaced once( under warranty).
I also started a thread " D.E.S.S KEY CODE AGAIN!!!!!!!!!!!!!!!!! on 8/13/2015 Replies 736 & 149,647 Views & 30 pages long. The thread has some very helpful info. Since I have had the D.E.S.S module , I have not had the D.E.S.S error show up. Also I have 24,900 miles on my spyder. On the "Thread" I posted pictures of the Orange Screen, when you get a chance take a look at the thread.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
Had my 2014 RT in the dealers shop 6 weeks last Summer. They said they could not duplicate the problem (DESS Error). Module has the "latest and greatest" installed. I've had 6 more DESS errors since I got the bike back. I just wait about 15 minutes - go back and it starts up. So not a big issue any more. Now I have a "Check Engine Light" that is on all the time plus the cooling fans starts when I start the bike (cold start) and cycles on/off as I ride. Bike is otherwise okay. I don't ride it much any more.
Did own: 2008, Red, SE5 - and 2010, Black, RT-S Premiere Edition Number 670
Now Own: 2014 Black RT-S SE6
![Quote](images/misc/quote_icon.png) Originally Posted by Don in E Texas
What is your D.E.S.S module part #?
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
![Quote](images/misc/quote_icon.png) Originally Posted by Deanna777
Deanna
Don't remember now... But was told here on the Forum it was the latest model. Have not heard of any other module since then.
Sorry - no help.
don
The current part number now being sold is 710004916. It shows it as a direct replacement for the prior 710004190
w6ada, Thanks for the update on the current dess part #.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
Got a DESS error code yesterday, I was hoping never to see this ![Frown](images/smilies/frown.png)
Good thing is that the bike ( after a few choice words) started up again 10 seconds later. Will this be the start of a module failure ? I'm hoping not. But thanks to this thread I'm fully informed.
![Quote](images/misc/quote_icon.png) Originally Posted by HayRog
I've posted quite a bit about this issue, including fixes ….. I see you have a 2015, if under warranty they WILL fix it. ….. Yes this was a warning, the DESS doesn't ever get better - it does get worse until it finally Fails completely..... that could be 5, 10, or 15 starts from now or the next time..... The latest START procedure ( If you have the Orange screen of death ) ….. is move the Spyder about 25 ft. away from where it is parked( if possible ) …. then turn key on - off 5 X's in succession quickly . Then try and start normally …. hopefully the screen has cleared …… If you have to buy the DESS module ( do not buy the Ignition switch - Yet ) CHEAPCYCLEPARTS.COM sells it for about $135.00 …… PM me and I'll help you re-place it …. I did this with " w6ada " …………….good luck ….. Mike
I often wonder why did they change the design of the DESS module in 2014? If it worked in 2013 and prior, why not just go back to those units? Remember the old saying, "If it ain't broke, don't fix it."
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
Member: American Legion
Experience is recognizing the same mistake every time you make it! ![banghead](images/smilies/banghead.gif) ![](https://www.spyderlovers.com/forums/maps/map.png?states=SC.NC.VA.KY.TN.GA.AL.MS.FL.LA.TX.MD.MO.IA.SD)
Its not fixed. Have seen it on a 2018 (which we turned off). The 2014s were widespread, later bikes not so much but it still happens.
Have never seen this on a single 2013 or earlier.
![Quote](images/misc/quote_icon.png) Originally Posted by Grandpot
The previous dess system is not the same as the 2014 on system. Currently the key code is held in the ECU and the dess unit is an intermediary, previously the key code was held in the dess unit. I've no idea why BRP changed it but, in my opinion it was less secure in the previous system. I looked carefully at the wiring diagrams for the previous system just in case I had a dess failure, I reckon I could bypass it with two connections. I'm guessing that BRP deliberately attempted to make the system more secure but mucked up electrically with the early (2014 >) units.
![Quote](images/misc/quote_icon.png) Originally Posted by Spyderlass
I'm sure they had good intentions. On the other hand, I have never heard of someone stealing a Spyder by circumventing the DESS unit on the early machines.
1998 Honda Valkyrie
US Navy Veteran
Just for sake of discussion, they made it LESS secure as it can now be disabled via software without a valid key. This is why I keep telling folks the DESS only serves to keep legitimate owners from riding the bike. Does extremely little to prevent theft.
![Quote](images/misc/quote_icon.png) Originally Posted by jcthorne
Mr. jcthrone,
Is the DESS able to be disabled via BUDS? The In Plain Sight key pretty much shows Spyders aren't swiped too often, so is it really as simple as that? Is this an option open via the dealers, I'm getting ready for my first service, so they may be able to head off this issue by a delete.
h0gr1der
![](https://www.spyderlovers.com/forums/maps/map.png?states=LA.MS.AL.GA.NM.AZ.CO.KS.OK.AR.TN.SC.NC.KY.IL.MO.IA.SD.WY.TX)
![Quote](images/misc/quote_icon.png) Originally Posted by BLUEKNIGHT911
I've posted quite a bit about this issue, including fixes ….. I see you have a 2015, if under warranty they WILL fix it. ….. Yes this was a warning, the DESS doesn't ever get better - it does get worse until it finally Fails completely..... that could be 5, 10, or 15 starts from now or the next time..... The latest START procedure ( If you have the Orange screen of death ![yikes](images/smilies/22yikes.gif) ) ….. is move the Spyder about 25 ft. away from where it is parked( if possible ) …. then turn key on - off 5 X's in succession quickly . Then try and start normally …. hopefully the screen has cleared …… If you have to buy the DESS module ( do not buy the Ignition switch - Yet ) CHEAPCYCLEPARTS.COM sells it for about $135.00 …… PM me and I'll help you re-place it …. I did this with " w6ada " …………….good luck ….. Mike ![Ohyea](images/smilies/ohyea.gif)
Thanks for the info and very gracious offer Mike. If it gets to that I'll contact you.
