Ill be swapping out the temp gauge soon to install a volt meter on the right side. I know the I have to disconnect the fuel gauge. is there a dummy cover or some other useful gauge to install there. ready to roll on some of my winter mods thanks.
What you want is part #705003421, Gauge Cap. That is the blank used on the RT base model. You don't say you have an RTS or RTL but I'm guessing that is what you have, right?
2014 Copper RTS
I have a 15 RT-S. I am looking to fill the hole with a blank or another functioning gauge of some type. If I where to install a clock on the left where would I get continuous power. what have some of you put in that space.
2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
2022 White Pearl F3T
Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
a clock would be a constant drain on the battery.
Cruzr Joe
I have two USB ports in the center of the handle bars , I have the volt meter ready to go just want some thing else to fill the void but some thing useful. I know i mentioned a clock and that would be a drain. I could mount a small nav but I am afraid that it would grow legs and walk away when I am not around, Keep the ideas coming guys as I am at a lost on what to put there. thanks
I don't know if there is a best . the unit I got was 25,00 bucks on Ebay. I saw some as high as 80.00, I thought that was a bit over the top so 25.00 was best for me..
