Nedd a 12 Volt Hookup by the Seat
Hey guys ordered some heated gear and need to make a hookup to the battery but the battery is like 6 feet from the seat - The question is; Is there a 12 volt hookup closer to the seat or under the cluster that would support a 15 amp draw?
Thanks In Advance
(Sorry for the spelling) LOl
My heated vest hooks up to plug we added to the customer accessory circuit hiding under the little safety card panel, on left - drilled a hole in the panel for the waterproof plug. Looks neat and works well. F3s.
I would love to know whether I can hook a usb up to the wires under the foglight button on the f3 s dash. Would this work? Would be handy for gps...
DIY
I bought a long battery tender lead from our local Cycle Gear store. I cut it half, made it about 4' long (+ or - a few of inches), installed two battery connectors on one end and the other end already had an SAE connector. On the positive lead near the battery connector I spliced in a fuse holder. I removed the left body panels and snaked the wire up to under the seat and it came out near the gas cap. Zip tied the wire in several locations to keep it from moving around. Under the seat there is about 16"s of wire that can be brought out (w/o crushing it) for easy connection access next to the glove box. Mostly I use it for running two sets of heated clothing. I've used it on occasion to charge my cell phone when I'm using it for a turn-by-turn navigation.
Powerlet jacks.
Mark in GA
2014 Cognac Spyder RT Limited - SOLD
2014 Cognac RT-622 Trailer - SOLD
12volt
I noticed the same thing when I went to hook up my heated gear. There is a wire running from the positive terminal of the battery to the alternator. To make the standard lead work, I tapped into this wire near the alternator.
2015 Can Am Spyder RT Limited
Sorry, missed this pic.
Mark in GA
kept it simple
hooked directly to the battery with factory cord [gerbing] purchased extension cord from ebay pull it out of the frunk when needed and leave it curled in the bottom when not
Both of the Powerlet jacks above are wired separately and directly to the battery with an inline 15A fuse. Requires removing tupperware to route the wires and place the fuse holders where you can get to them if need be.
Mark in GA
Thanks In Advance
There are three accessory circuits. One up by the battery, second under the left panel with the twist knob, it's hard to find, but it's there. The last and easiest to find is under the passenger seat
Chris
2016 F3-T SE6
Yes, always keep it simple
Run your heated clothing directly off the battery. I used a splitter after my main lead comes out from under the seat. When not in use, the main lead stays hid under the seat. By the way, always have an extra splitter tucked in your coat pocket. Somehow they become easily misplaced. When you're somewhere out in the middle of Nevada at night, and you can't find the splitter for you and your wife's heated jackets, it can be a long cold miserable ride to find another one.
Heated gear has a relatively high current draw. That's why it needs to connect directly to the battery.
Mark in GA
I already had an SAE connector for the battery tender so I just bought an extension cable and ran it up under the seat
Sent from my SAMSUNG-SGH-I747 using Xparent Skyblue Tapatalk 2
JLohPhotos
I noticed the tech at our local dealership hooks the leads to the alternator under upper side panel on left side of bike. We needed to change a fuse on s friends bike at Red Rock Rally and found the plastic needed to be removed. If I used that location I would make sure fuse location was easier to get to. I realize that the fuses should be as close to connection point as possible, though.
2015 an Am Spyder RT Limited
2013 Yamaha WR250R - Sold
2011 Can Am Spyder RT-S SE5 Limited - Sold
2011 Aspen Sentry Trailer
2003 BMW K1200LT - Sold
2007 Unigo Trailer - Sold
2001 BMW K1200LT - Sold
2001 Honda 750 NightHawk - sold
2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
Jim
2013 ST-S (wife's)
2015 BMW R1200GS (mine)
1981 Yamaha XS400 Scrambler Custom (mine)
What does the one under the left panel look like, colors?
2014 Spyder RT Limited, Lees-sure Excell camper, Aluma MCTXL Trailer
