what pressure for the air shock in a rt
hi guys.
question to help out a buddy.what pressure reading should you get at the shraeder valve if you had the shocker on max setting and min setting.its a 2012 rt ltd 998 cc
its just he cant get a roll in hoist under his middle chassis rail,its too low.i checked it at max setting and it read 32 psi.
also for general info,will the air pump only run when the bikes in gear and moving.as you cant hear the air pump fire up at rest.
thanks and cheers
stu
Stu, the answers to both of your questions are in the Owners Manual. There also is a sticker located near the schrader valve that has the pressure settings. The Spyder must be running and in gear for the compressor to kick on. 32 psi is pretty low, I believe the maximum is around 65 psi.
If you don't have the manual you can look it up online at www.can-am.brp.com under the Owners tab.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
When I had my 2012 RT, I kept the shock air at 50lbs at all times. About half the time that was with 2 up riding. Seemed to be a happy medium for me and Pebbles.
Current Ride
2015 RT-S SM6 Cocaine
Pearl White
Diamond R Web Armrests
Shorty Windshield
Previous Ride
2012 RT SM5 The Beast
Pure Magnesium Metallic
ok thanks for help,ill check the book info and other tips
cheers stu.
Bob is correct in that the air suspension is position based on the Limited. If you need to raise the rear a bit, with the key off add air to the schrader valve and the bike will come up. When finished with the maintenance just ride the bike and it will reposition itself. The beauty of a Limited
It might be a bit simpler to ride the rear or front tire up on a 2 x 6 to get the jack in.
