Results 1 to 7 of 7
Thread: Stereo
    Sep 2016
    US. ohio n/e
    Default Stereo
    I have 2014 rts....is there sub line out on the radio unit...if not is there a way i can get one...tks dave
    Sent from my LGLS675 using Tapatalk
    Default SUB LINE OUT
    Quote Originally Posted by amelectricdavid View Post
    I didn't see one when I worked on mine ......However I would contact a member here " Bluestratos " , I know He did a Sub on His, so He could tell you how .... Mike
    Probably. There are no line out connectors on the radio, but there is a connector for the optional CB radio. The CB carries the audio from the radio to the headsets so I'm guessing that 3 or 4 of the pins in that connector are line level audio. The wiring diagram doesn't identify which pin is for what signal but Bob White, (Finless), may be able to tell you. If you're comfortable with working on the connectors on the radio then PM Finless and see if can get the info for you.
    Sep 2016
    US. ohio n/e
    Cool tks
    Very Active Member finless's Avatar
    May 2013
    Stanton, ca
    See this thread where I figured out the BT dongle. Those are the audio out wires.
    Bob
    http://www.spyderlovers.com/forums/s...our-own-Dongle!
    2011 RT-S SM5 - Black
    Jun 2019
    NC
    Does anyone have the pin out locations/numbers to make a cable from the RT radio line out connector plug to plug into a BT transmitter? I can make a cable but would like know the pins to connect too before hand to save time. I don't need the power pins cause I will use the accessory jack in the trunk to power the transmitter I have. Does Motorcycle Dave's have just the cable? If so how much is it and has anyone used it? I'm not interested in the Sena SM10 dongle cause already own a transmitter I can use.
    Feb 2012
    Spring City,Utah
    Yes you can get the cable from motorcycledave. Call him for the price. It works real swell I have been using it for 3 years.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
