Brake failure code c1282
Put rear tire on now brake failure on screen brakes seem to work fine any help would be greatly appreciated
Sent from my Z958 using Tapatalk
Brake Failure message with a C1282 code has nothing to do with brake fluid level. That is a low pressure fault. It can only be reset with BUDS or a short procedure by the operator. Make sure the key has been turned off for more than 30 seconds. Turn on the ignition key. Wait for the screen to finish booting up. Press the brake pedal hard enough to activate the low pressure switch. If you have good hearing it will be the 2nd click. While holding the brake pedal down. Turn the ignition key off and wait 30 seconds. Release the brake pedal.
So how did you get a low pressure fault. A leak in the brake system? Bad fluid?
brake failure code
2018 F3-T
Changed rear tire code came up brakes feel fine
When I get home I'll try your suggestion
Ok that explains it. You pushed in the rear brake caliper piston. Then the first time you press the brake pedal is with the key on. The pedal traveled too far before the rear brake circuit pressured up. Next time press the brake pedal a couple times until it firms up before you turn on the key.
Agree...
was my next thought...always start with the last thing you did or happened....
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
I sure appreciate y'all's help. I'm a few years n age couple of heart attacks still do my maintenance my bikes fairly easy spyder fairly hard thank you
Done the key mashed brake fixed it. Thank you
