Results 1 to 25 of 48
Thread: Belt damage
    Dec 2014
    NY
    Default Belt damage
    So I'm in for 9,300 service, and I'm told that the belt has been damaged, probably from a rock. There is a little fraying on the inner edge and part of the teeth. This will be an $1,800 job with both sprockets having to be replaced. Anybody want to chime on on this?
    Sent from my XT1585 using Tapatalk
    I'd want to see the damage to the belt and both pulleys...
    And for $1800; what they're doing to you, shouldn't be discussed in "Polite Company".
    Default Agree...
    would have to see the damage to determine if those parts need changing. It would have to have been a big Rock and lodged for time and noticeable. ..jmo
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    I agree, there's a smell test here that doesn't pass. From the 2015 F3 parts list the three parts requiring replacement total $865 in round numbers. Does the Spyder dealer work out of a bay in a Ferrari dealership to justify a grand in labor?
    Active Member Mikind7's Avatar
    Apr 2015
    Orangevale Calif
    2015 F3 SE6 Black and Chrome, Smoothspyder Backrest and more to come.
    If you have collision coverage on your bike: you might want to give your insurance agent a call, and see if this is covered.
    (It should be!)
    I have had two drive belts replaced. Both were $350 installed. Belt was about $250 ish. Tows were extra.
    $1,800?...hold on to your wallet, protect your rear, and get at least a second opinion.
    Apr 2012
    Northglenn Colorado
    I am surprised everyone so far is shocked that dealer is charging 1k in labor. When I complained that the dealer wanted 300.00 for labor to install new front shocks that should at most take 1 hour, people pored out their hearts for the dealer saying they had to make a living!!!!
    United States
    Very rarely does a sprocket need replacement with the belt. Would have to be something substantial to have caused sprocket damage and probably would have shredded the belt in the process. Sounds like the belt was misaligned for a while and it damaged the side.
    It would be curious to get it correctly aligned and see just how long it would last. I don't think a little damage on the edge even warrants a change. A rock hole in the center, or rib damage, maybe stress cracks on the outer surface, yes. But a little rubbing damage on the inside, probably not in my opinion.
    United States
    Try to get a picture and post it. That should tell a lot.
    Nov 2015
    Myerstown, Pennsylvania
    Default State inspection....
    I was charged a full hour of labor for PA state inspection at the new local dealer. I was only there for a half an hour & it was a new vehicle. Probably didn't check anything & just put the sticker on. I'll find out if they are a good dealership when I take it back next year for front end alignment & oil change.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Dec 2014
    NY
    I will post a pic, but the dealer claims that BRP wants both sprockets replaced when the belt is. They said there is a slight chip in a rear sprocket tooth.
    Sep 2008
    Yorktown, VA
    In Virginia the state inspection fee IS the labor fee for the inspection. So I think you've already found out if they are a good dealer or not.
    Quote Originally Posted by SteveLaoyster View Post
    Bruce
    Yorktown, VA
    '08 Spyder GS
    Quote Originally Posted by johnny pop View Post
    Based on what I am hearing about the dealer--please seek out a second opinion. Trust, but verify seems to be kicking in big time here.
    Dec 2014
    NY
    These are the best I could do. Thanks for all your responses. Right now I'm leaning towards having a non- BRP mechanic just change the belt out next spring.
    Thanks for the photos. As a non-mechanic, I am not seeing enough damage to replace. I would recommend watching to see if the damage grows on the next ride or so--or if the belt heals itself from further running.
    I am guessing you will get some additional good advice from those in the "know."
    Sep 2016
    N.E. Ohio
    I've been riding belt drive Harleys since they ditched the chain. If the belt has a hole in the middle, maybe caused by a stone or gravel, don't worry about it. If you have a tear on the edge, replace immediately. I don't see any tear in the belt that would warrant replacement
    SpyderLovers Sponsor
    Jun 2010
    Las Vegas
    Haven't there been some issues with sprockets on the F3? I'd get another dealer to look at it and push them to contact BRP about warranty.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    I would keep riding it ,but inspecting It before every ride, looks ok. $1800 is every high, I would inspect the sprockets myself.
    Very Active Member Sam Mac's Avatar
    Dec 2015
    Galax VA
    As long as the out side of the belt isn't ruptured I'd run it. It's the outer band that transmits the power. If you have a couple nicks on the pulleys I'd clean them up. My guess is that belt will last many thousands on miles.
    Here's what my owner's manual shows for how to deal with belt damage:
    Since yours looks pretty minor; I think that just keeping an eye on it, is the way to go.
    United States
    A file can clean up that chip on the sprocket fairly easily. Did that to mine about 20k miles ago when I got a chip. Still running the same belt with no problems. Make sure it is smooth to the touch. I would monitor and ryde it. That is very minor damage.
    Feb 2012
    Spring City,Utah
    Owners manual to the rescue again
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Default STATE INSPECTION
    ......In Vermont the DMV can / will provide to anyone what the Inspection requirements are for any Vehicle ...... you might want to check in Pa. what yours are ...... A complete legal Mtc inspection in Vt. takes 10 minutes - if they are slow about it ..... Mike
