Results 1 to 9 of 9
    Very Active Member Trbayth's Avatar
    Jun 2014
    Schenevus NY
    Default Here's a problem I haven't seen here before
    Haven't seen this here before. This was one of the bolts holding on the engine filter cover. Now it's garbage. I dodged a bullet in that the broken off piece was sticking out of the engine enough I could get a grip on it with pliers and back it out.
    Anyone know if you can buy those bolts separately? Cheap Cycle Parts maybe?
    Trb-- (Roger)
    2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    2022 White Pearl F3T
    Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
    Spyder States Visited
    Jul 2011
    Mitchell, Ontario, Canada
    Is that the right bolt? Looks like the longer one from the HCM (trans) filter. It's longer but hard to tell from the picture. If you mixed them up. That may be why you twisted it off. Now the other problem is if the short bolts are in the trans filter. That going to strip out the threads. Several folks have striped the threads with the right bolts.
    Engine filter bolt: 205063044 Socket Head Screw M6 X 30
    Trans filter bolt: 420241811 Socket Head Screw M6 X 35
    They are about a $1.00 each from BRP.
    2018 F3 LIMITED
    Jun 2014
    Schenevus NY
    I'll double check of course but I'm always careful to do just one filter at a time. Remove cover, replace filter and o-ring, replace cover.
    Also looks like you have to order them in quantities of 10 from BRP.
    Trb-- (Roger)
    Jul 2014
    Mint Hill, NC
    A good hardware store should have either length bolt in quantity ea.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jul 2010
    Las Vegas, NV
    Default Industrial supply store
    Most places have an industrial supply store; we have McFadden Dale, Fastenal, Nevada Bolt, and ACE. Those bolts are common sizes. Bolts break and strip. Replace as required.
    Joe Meyer
    Default Well....
    with the bolt mix ups but if you do one at a time, as I always recommend, it may be that that one has been over tightened a time or two and just gave up...
    ​2012 RS sm5
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    You can get metric bolts at any Ace Hardware Store
    Jun 2014
    Schenevus NY
    Problem solved courtesy of Lowes.
    Fresh oil and almost full tank of gas, treated with Stabil. Let it snow!
    Trb-- (Roger)
    Jun 2013
    queens ny
    i said a long time ago, that BRP uses cheap bolts. they are not hardened. i tried to remove a fender support bolt, and it broke on me
    NO BIKE AT THIS TIME
