Results 1 to 19 of 19
    Sep 2016
    Jackson, Michigan
    Default Fog light recommendations - 2016 F3T
    Good evening! I am looking for LED fog light recommendations on our 2016 F3T. Thanks in advance.
    ~Laurie
    Mark & Laurie - we have crabs and a Spyder - 2016 F3T-SE6
    Very Active Member armyspydervet's Avatar
    Nov 2015
    Occoquan, VA
    Lamonster Garage...second to none
    Chris
    2016 F3-T SE6
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by crabbylady66 View Post
    ~Laurie
    I, too, have to say Lamonsters Garage.
    If you're going to get his LED fog lights, do yourself a favor and change out your headlights to LED's too. You'll kick yourself in the butt if you don't.
    2020 RT Limited , Chalk
    Another vote for Lamonster's flame-throwers!
    Active Member tmcquain's Avatar
    Apr 2016
    Tennessee
    Lamonster LED headlights and Foglights....nothing better IMHO !
    " Fat people are harder to kidnap "
    2015 RTS-SE6 Circuit Yellow
    Akrapovic Exhaust - BajaRon Sway bar
    Rivco rear Trunk Rack
    Lamonster LED Head Lights - LED Fog Lights
    Spyder Cuff - Hwy Pegs
    Ultimate Midrider Seat w/ Yellow Trim - Rear Armrests
    Spyderpops Bumpskid with LED - Full view Turn Signal
    R/T Front grill Inserts
    3rd Brake light - Saddle bad LED
    Baker Built Air Wings
    Doc's Spring Stiffeners - Vibration Dampener
    TRICLED underground LED'S
    Aug 2007
    Springfield, MO
    You can't have too many lights. And if you do, they should be the good stuff. These are them.
    Invalid Emails
    Jun 2014
    Green Lake, WI USA
    Have both the LED foglights and the LED headlights from Lamonster! Awesome!
    Active Member CA Railwhale's Avatar
    Aug 2016
    Sun City West, AZ
    Default Combination
    If you are going with the Lamonster lights, add the Fog Rings and the BRP heat shields. The Rings add a lot of light and visual effect and the heat shields give a nice finished appearance for an additional twenty bucks. The combination of the fog lights and rings pretty much fill the holes in the heat shields. You might as well do it all at the same time since you will have the tupperware off anyway. I left the factory headlights in place, since the two colors of light seem to be more visible than four lights of the same color during the day. I may change out the headlights when one burns out.
    Active Member Vegasf3t's Avatar
    Sep 2016
    Las Vegas nv
    Here is another option: Tricled LED Halo Fog Lights. Dual function: White LED running lights and amber turn signals. Had these installed at Red Rock Rally recently and very pleased.
    Active Member Gsebring's Avatar
    Oct 2016
    Houston
    Default Heat shields
    Quote Originally Posted by CA Railwhale View Post
    Where re would we find the heat shields? Do they come in the kit with led fog lights?
    Aug 2016
    Sun City West, AZ
    Default Heat Shields
    Quote Originally Posted by Gsebring View Post
    Just order them from your Spyder dealer, they are less than ten bucks each including tax in California. They replace the blanks for the fog light installation. Some people have cut out the blanks, but for twenty bucks I liked the factory finish better. (I tried the other route using a hole saw, but wasn't happy with the holes and sanpped one of the blanks in half when the hole saw grabbed).
    Mar 2013
    Maumelle, AR
    Will the heat shields work with Lamaonts LED fog lights?
    Also, I just looked in the 2016 accessories catalog and could not find the heat shields. Any idea of the part number?
    Aug 2016
    Sun City West, AZ
    Quote Originally Posted by Copperman View Post
    I have both the Lamonster Fog Lights and Fog Rings and together they just about perfectly fill the holes in the heat shields. The Fog Lights alone will leave about a 3/8s inch gap in the holes of the heat shields. I looked up the parts number for the heat shields for you, in the 2016 model, they are under Body and Accessories-general. They are item 119, the parts numbers are 705008995 (Left Hand) and 705008996 (Right Hand) They are easier to find in the 2015 drawing, since they are listed under faring parts. The parts number is the same for 2015 and 2016 models. Good luck with your mods.
    Aug 2016
    Sun City West, AZ
    Here some photos
    Mar 2013
    Maumelle, AR
    Thanks.
    Oct 2016
    Houston
    Default Lights
    Pics don't do then justic, just installed the fog lights with halo ring and headlights. They are blinding bright. Lamonster shipped fast and had them in 3 day. Very happy with there products.
    Jun 2016
    INDIAN Wells
    Quote Originally Posted by reissooz View Post
    Ditto for me....They are the best, I have both too.
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    Quote Originally Posted by Lamonster View Post
    Lamonster Garage is the best place for all of your spyder needs.
    Bought Lamonster LED fog light and Amber blinking turn signal rings that mount on the fog light bezels. and LED headlight kit and Jacob installed them for me while I was at Lamonster Garage,
    Awesome product and the amount of light produced is way better than stock headlights and fog light kit.
