Page 1 of 2 12 LastLast
Results 1 to 25 of 35
    Active Member Johnny_Swindle's Avatar
    Jan 2013
    Ponchatoula, Louisiana
    Default Can't get the $#%$ trailer hitch ball off the sypder
    Need to remove the trailer hitch ball from the BRP hitch. I can't get it off. I about gave myself a hernia trying to wrench it off . Is there any special trick?
    Thanks.....
    Johnny
    2015 RT-S (SE6) Special Series
    Very Active Member youngers's Avatar
    Sep 2016
    clark county indiana
    wear a weight lifters belt { hahahaha sorry , but I have had too use a very large crescent adjustable wrench and a rubber mallet , just too pop these loose , it is the lock split washer on bottom that is the holder of this deal } remember , turn head and cough , too check that hernia
    Jan 2013
    Thank you for the kind words . Will take a break and tackle it later.
    Quote Originally Posted by youngers View Post
    Johnny
    Sep 2014
    USA
    you need leverage Long pipe or wrench. Impact gun could possibly help too if on hand..
    believe its 36 mm or at least mine is..
    Very Active Member DJFaninTN's Avatar
    Sep 2013
    Panama City Beach, FL
    long strong pipe over the wrench and she'll bust loose
    2015 RT Limited Intense Red Pearl
    with the pipe tactic!
    Archimedes once said: "Give me a place to stand and with a lever I will move the whole world."
    Jan 2013
    You are correct....and I was using "cheater" on the wrench....
    Johnny
    Jan 2013
    True....I guess I will need to look for a longer pip to put over the wrench....
    Quote Originally Posted by DJFaninTN View Post
    Johnny
    Jan 2013
    Did he get a hernia??
    Johnny
    Nov 2015
    Chardon, OH
    Quote Originally Posted by Johnny_Swindle View Post
    Thanks.....
    If it was installed per the instructions, then red Loctite was used on it. Good luck with.
    PS. And torqued to 160 ft-lbs.
    Doug
    ”Freedom is not a loophole”
    Jan 2015
    southern WI
    Soak it over night with penetrating oil, smack the nut a half a dozen times on each side with a hammer, and of course a cheater bar. If none of that works, heat it up...it'll come off
    2021 RT Limited
    2016 RTS , Pearl White
    Jul 2010
    Las Vegas, NV
    Default Red locktite
    Requires heat to remove. Heatgun or torch. It is glued on!
    Joe Meyer
    Mar 2013
    I used my 1/2" air impact and it came right of, but if that didn't work I would have used 1" black water pipe over the breaker bar handle. At lease twice I have had to used a 5' long pipe to get a nut off
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Quote Originally Posted by cptjam View Post
    May 2013
    Stanton, ca
    Yep... I had to use a torch to heat it up. Apply heat to the nut as it is red locktited....
    Bob
    2011 RT-S SM5 - Black
    Jan 2013
    That is what I thought............I hate it when people follow the instructions.
    Quote Originally Posted by Snowbelt Spyder View Post
    Johnny
    Jan 2013
    Heat may be in order.....
    Quote Originally Posted by Mazo EMS2 View Post
    Johnny
    Jan 2013
    Johnny
    Jan 2013
    I will have to do that....
    Thanks...
    Quote Originally Posted by finless View Post
    Bob
    Johnny
    Sep 2012
    Junction City, KS, USA
    I showed my bro, Stony Rodent, this thread because he was gonna remove my hitch ball this week. I was afraid it was gonna be a bear to do. Then he shows up in the kitchen this morning with the ball. He wedged a pry-bar underneath so the nut couldn't turn and turned the ball with a 2-ft crescent wrench. Easy peasy!
    PrairieSpyder (Patti)
    Jan 2013
    Work has keep me busy so I have not attempted the trailer hitch ball....but I will have to soon.
    Quote Originally Posted by PrairieSpyder View Post
    Johnny
    Very Active Member garb55's Avatar
    Coolidge Arizona
    Default Heat
    Bring it to Arizona in July
    The ball will come off easy
    Now 2014 RT Limited Cognac
    Was 2008 GS SM5
    Don Garbarino
    Cup Holder
    GPS locking holder
    Mud flap
    Modified KNOTT grill
    Phone holder and charger
    Trailer hitch
    Dual air horn
    Auxiliary fuse box with relays
    Heated clothing controller
    volt/oil pressure gauge
    Sequential signals in mirror
    Tri Axis Handle bars
    Baja Ron anti sway bar/heim links
    shorty antenna
    And many more
    Jan 2013
    You are correct....was stationed at Luke AFB and I remember how hot it got in the summer....
    Quote Originally Posted by garb55 View Post
    Johnny
    Nov 2013
    Oro Valley Arizona
    And if all else fails remember--Righty tighty, Lefty loosey! Remember it is upside down. Happens a lot.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Jan 2013
    Quote Originally Posted by jaherbst View Post
    Jack
    You are correct...[emoji1]
    Sent from my SM-G935V
    Johnny
