Results 1 to 8 of 8
    Active Member commanderjb's Avatar
    Aug 2016
    McKinney, TX
    Default 2013 ST dash question
    I was thinking about installing a dual USB port in one of the blank switch holes on the dash in my 2013 ST. When I popped two of the covers off, I found two blocks (see pictures).
    Can I wire the USB port into one of these blocks? Are they hot already?
    In an orderly world, I'm addicted to chaos.
    Greenville Tx
    The block on the far right is for the fog lights and the one next to it I
    think is for heated seats. They should be hot. You just need to do a little research on to what color wires to tap into.
    2017 F3 Limited
    Aug 2016
    McKinney, TX
    Quote Originally Posted by AY4B View Post
    Thanks.
    Anyone know which wires to tap into for the power in the heated seat block?
    Jul 2011
    Mitchell, Ontario, Canada
    The outside right is fog lights. Second from right is air suspension and is not documented on the wiring diagram because officially it is not an option on the ST.
    Go with the fog light plug. The running light circuit that lights up the switches is orange with a red tracer. Goes on and off with the key. Would be fine for a usb plug.
    The fog light circuit is light green with a gray tracer. It goes on and off with the load shedding relay that energises when the engine starts.
    Ground is the black wire.
    2018 F3 LIMITED
    Aug 2016
    McKinney, TX
    So I should use the orange with red tracer wire and the black ground wire?
    Jul 2011
    Quote Originally Posted by commanderjb View Post
    Sure, if you want on with the key.
    2018 F3 LIMITED
    Aug 2016
    McKinney, TX
    Perfect. I only want it powering when the key is on.
    Thanks for the assistance.
    JB
    Registered Users GMAN9's Avatar
    Jul 2008
    Lowell, NC
    Default Follow UP
    Please follow up with another post and let me know how it went. I would like to do that also. Let me know of any issues that you may come across, also maybe the USB that you are using.
    Thanks,
    2013 ST-S Circuit Yellow Metallic
