Results 1 to 17 of 17
    Sep 2016
    Pueblo Colorado
    Default Washing the machine
    So thinking about taking the spyder to a car wash. Is that contraindicated from you senior spyder specialist? Thanks in advance [emoji106]
    Sent from my SM-G900V using Tapatalk
    Very Active Member Buckeye Bleau's Avatar
    Aug 2015
    Canton, Ohio
    This is a question that has been answered too many times but ok.
    First, I know many that take it to a spray wash and do well. This works especially well to remove our brake dust accumulations that cause that brake squealing noise, just make sure that you don't direct the pressure at the electronics, dash area.
    That being said, I only use a microfiber towel and one of a few cleaners. I started out using Multipurpsose Pledge and it was just dandy, removed bugs quickly, dirt grease and grime while leaving behind a polished look and deep shine. Then I got a bottle of Lamonsters Diamond Polish and I now use it with the microfiber towel, it just works great.
    Ryde on, with a sparkle!
    Joe
    U.S. Army Viet Nam Era Vet
    Utopia Deluxe driver backrest
    LED fender lighting
    Fast Flash LED brake light
    Spyder Pops LED/skid plate
    May 2013
    Apex, N.C.
    I think you will be fine. Just remember not to spray full pressure in some of the sensitive areas. I actually washed mine at a car wash in Maggie Valley before leaving the rally this weekend. Not really to clean the spyder, but to clean my Doc Humphries Rack before mounting the pack on it for the trip home.
    Jun 2014
    ny
    i bring mine to the local spyder wash
    Aug 2013
    Northern California
    Default No need
    We take cotton towels and soak them in hot water and then drape them all over the Spyder and let it soak for 20 minutes or so. Then we wipe the surface and dry with microfiber towels and then hit it with Lamonster Black Diamond Detailer. We do this after every ryde and we have beautiful results. The key is to not allow the dirt to accumulate.
    Jun 2014
    ny
    When needed i use sprayway instant detail cleaner, works great for bird poop & gnats too.
    Member GandM's Avatar
    Oct 2015
    Pigeon Forge Tn.
    Default drying a spyder
    Just a tip when I was the spyder at home I use a leave blower to remove water from all the little nooks and crannys.
    I guess that I'm too cheap, to pay for using a car wash...
    Soap and water at home works just fine for me!
    Registered Users lou49's Avatar
    lake mary fl.
    Quote Originally Posted by GandM View Post
    I personally don't like putting water on my machine! Honda has a bike cleaning product that works very well for me! Just spray and wipe!
    Sep 2011
    Austin TX
    Default high pressure water
    keep the high pressure away from all wheel bearings.
    Quote Originally Posted by lou49 View Post
    Don't ride in the rain, huh?
    The only time water has caused a problem for me was riding through 1" or 2" of standing water at 30+. Enough got thrown up under the tupperware that the CB radio, not sufficiently water tight from the factory, got wet inside and died.
    I find washing any vehicle to be a distasteful chore. I consider it a significant concession to practicality just taking my Spyder to a car wash to clean it off. Super soak, wheel wash, pre-rinse, foam brush, high pressure wash, then high pressure rinse, and I'm done. Paper towels work to dry off my F4 windshield, and my blue jeans dry off the seat quite nicely!!
    I don't remember what it was called on the wash menu board, but at an Iowa car wash there was a choice for something like a super pre-clean low pressure spray that worked unbelievably well. Grasshoppers, other bugs, and dirt, loosened up so well I did not need to use the foam brush. Pressure wash and the crud just flew off!
    lake mary fl.
    Don't ride in the rain unless I have to! But when I do, I still use the Honda cleaner! Spray n wipe!
    STAY DRY MY FRIENDS!
    Vermont
    I use soap and water and elbow grease. Also, I don't use the car wash. I use a chamois cloth to dry off my spyder with.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Default Depends....
    If you can control pressure and spray only in a downward motion, like rain, you should be fine. Spraying up under and on controls and instruments with high pressure will lead to problems...microfiber and spray on polish/cleaners work best for me...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    lake mary fl.
    [QUOTE=IdahoMtnSpyder;1190079]I find washing any vehicle to be a distasteful chore. I consider it a significant concession to practicality just taking my Spyder to a car wash to clean it off. QUOTE]
    That's fair enough: you hate washing them, as much as I hate paying to wash them!
