RPM shift point
Recently did a multi day test ride on a "16 RT (less than 50 miles on it) . Dealer said recommended shift point was around 3500. Is that a break in shift point or an all around number. Thanks.
I shift at about 3000 rpm, typically. The 1330 engine has very nice low-end torque that works well at that rpm.
Mark in GA
2014 Cognac Spyder RT Limited - SOLD
2014 Cognac RT-622 Trailer - SOLD
I wait until at least 4,000 before i shift and then the new RPMs are not below 3,000, makes for a great ride
Cruzr Joe
Don't know. ..!!
On the new hydraulic clutch if they have an rpm rating at fully engaged. Ideally you should shift at an rpm that when the next gear engages the rpm's do not drop below fully engaged , semi automatic engines. Manuals pretty much don't lug the engine. You will get more ranges to see where others are shifting...
2012 RS sm5
Cruzr Joe
you'll notice the gas mileage difference?
Shifting into second and third: I use 2,000 rpm
Fourth, fifth and sixth get pulled at 2,500...
try getting those RPMs up there Bob and you will see quite an improvement in power. IMO, you are shifting way too early, but that is just my opinion
Cruzr Joe
I'm shifting between 3.5k & 4k. Keeping it in the lower power band. I'm getting low 30's gas mileage just around town & driving to work. No highway miles yet but I'm sure gas mileage will go up then. I'm not getting it into 6th gear a lot.
AKA Jud Smales, Four Year Spyder Ryder!
"Quando Omni Flunkus, Moritati"
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Driver & Passenger Gel Pads in Seat
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
Break Stripe Kit from Wrap My Spyder
All the great movements in the world began with a cup of coffee!
2018 F3-T
My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
Trb-- (Roger)
2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
2022 White Pearl F3T
Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
Spyder States Visited
I'm in the gang that routinely shifts at about 3K; I can tell by sound when I'm there. If I have on my hooligan spirit I run it up as high as around 4K. My mileage goes down when the hooligan comes out but it's more fun.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
I bet she likes it that way
Now 2014 RT Limited Cognac
Was 2008 GS SM5
Don Garbarino
Cup Holder
GPS locking holder
Mud flap
Modified KNOTT grill
Phone holder and charger
Trailer hitch
Dual air horn
Auxiliary fuse box with relays
Heated clothing controller
volt/oil pressure gauge
Sequential signals in mirror
Tri Axis Handle bars
Baja Ron anti sway bar/heim links
shorty antenna
And many more
Thanks for all the replies (info).
The STS is going very shortly.
i always shift by ear, if it sounds right i shift,
NO BIKE AT THIS TIME
Ozzie Ozzie Ozzie
Reason: The other right! It's a Spyder, not the TV remote!!
