Page 1 of 2 12 LastLast
Results 1 to 25 of 27
    Very Active Member vtrider's Avatar
    Jul 2008
    Cambridge, Vermont
    Default LED Lighting, Is too much too much?
    I have asked this before in a previous thread when I owned my RT. Now that I have my F3 I want to add more LED lights to the front and rear of the spyder. I already added LED headlights from Xenon Depot, fender and saddle bag side marker LED lights from TriLed, Fog Lights and the longhorn mirror light kit from Lamonster garage and considering the dayrunner A-arm LED strips, as well as the cyclops LED for the front of the trunk. I guess I have to ask if all that lighting is legal? I already get high beamed now with some approaching vehicles on the road when my headlights are in low beam. I guess the bright led fog and headlights confuses people. Now if I do add the day runners and cyclops will that just add to the confusion from people? What are some of your thoughts on this matter, anyone?
    Jul 2010
    Las Vegas, NV
    Default More is better!
    You can never have too much light!
    Joe Meyer
    I'd rather that they be a bit confused; than unaware!
    Jan 2015
    southern WI
    Nah...light it up!!
    2021 RT Limited
    2016 RTS , Pearl White
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    if you really want to know if "all that" is legal, maybe in some states, not in others. Consult YOUR DMV
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    May 2015
    Oregon, USA
    If they flash their brights at you, then at least you know that they see you.
    Mission accomplished!
    -Fratz
    Very Active Member SpyderHands's Avatar
    May 2016
    Central Florida
    If you want to live longer, light it up brighter!!!
    I'm all about lights and sound.
    i want to be seen and heard.
    HAND'S UP:
    The only sure way of getting rid of bad habits is to create good ones.
    AND, by the way, this will not happen on auto pilot.
    It's time for a YOU-turn!!!
    Jul 2008
    Cambridge, Vermont
    I found this link which shows the laws regarding vehicle modifications from all 50 states. http://traffic.findlaw.com/traffic-t...tate-laws.html
    I checked this link as well for VT in regards to lighting http://dmv.vermont.gov/safety/safety/equipment. From what I can see if you are adding extra lighting to improve safety it should be fine, as long as it is not glow lights flashing or running. I believe the white day runner lights for example should be fine is in my sate.
    Active Member deer30084's Avatar
    Jun 2016
    Tallahassee, FL
    You might also want to wear a reflective vest and put a strip of reflective tape on the back of your helmet.
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
    Sep 2016
    Roswell Georgia
    Might want to check out this video, this guy warns of adding too many extra LEDs to the Spyder
    Registered Users lou49's Avatar
    Sep 2013
    lake mary fl.
    Quote Originally Posted by cptjam View Post
    washington state
    It never fail, every time you mess with the original design you taking a change of messing it up and always asking the question, What the #### happened?
    2012 Spyder RT SE5 Brake pedal mod
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by jtrobaugh View Post
    It is also more of a message to avoid putting cheap overseas crap on the Spyder, jt. He even mentions a supplier by name, saying that their stuff is OK.
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Lights are good. I am one of the few that rides with high beams on all the time. We don't ride in the dark here (to cold on those Oct/Nov nights), so it is mostly day time operation.
    The high beams help to avoid the "flashing" that appears to take place when the goes over a bump in the road.
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Default Just Use Common Sense
    I also agree with those sentiments. Here is my take on the subject of extra lights, FWIW. Some other folks will definately disagree...
    Legality - Official DMV rules do vary from state to state. I wouldn't worry about ANY of them. As long as you use common sense, like not putting red lights on the front and white lights on the back, or flashing lights that emulate police lights, etc., you very seldom EVER hear of anyone getting into trouble with extra lights on a motorcycle. Most all police and inspection stations realize that you are doing it as a matter of safety.
    Confusing other Drivers - I agree with what Bob D. said above. No amount of extra lights are a problem in the daytime. The more, the better in order to help avoid other drivers from turning left into your path, or ramming into you from the rear. As for night driving, I would simply avoid bright lights that are aimed high enough to blind oncoming drivers. The TricLED high-density daytime running light strips, that mount on the upper A-frames, are NOT a problem in that regard.
    Problems from Interfering with the CAN Bus - As the guy in the video says, this can happen with certain installations - especially cheap or excessive LED's. I have the Custom Dynamics LED high brake/running lights, the Signal Dynamics Wig-Wag brake modulator, and the TricLED high-density DRL's installed. NONE of these cause any problem with the CAN bus. If adding a bunch of LED effect lights, I would use a separate fuse bus, taking the power directly off the battery, which should avoid any problem. As the guy in the above video said, just don't tap into any power source that seems handy. If using TricLED products, I would check with their customer support folks with any specific installation concerns. They have very good customer support.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Oct 2013
    Pottstown, PA
    I would think and hope that MOST Spyder and motorcycle riders run with high beams on all the time, regardless of some of the comments posted here on the forum from time to time. It makes sense from a safety perspective.
    I always have both high beams and fog lights on. The two exceptions are when approaching oncoming traffic at night, or while stuck in stop-and-go traffic during the day.
    Vermont
    Quote Originally Posted by vtrider View Post
    I have LED's on the back of my spyder running/brake/ turn and they are bright. Also, I have side markers, and red/amber on my front fenders. I want to be seen.
    See pictures: FRONT FENDER+ SIDE LED'S 001.jpg LED'S lights on a 2014RTS-SE6 005.jpg
    LED'S lights on a 2014RTS-SE6 010.jpg Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Sep 2016
    Alma,Arkansas
    Default LED lighting too much
    Maybe I slept through the video, but what was his point? He talked about a Lady trying to go to Alaska and having a problem, a VCM problem. So what was the fix,problem and/or solution? He disabled a trunk light, how did he know to do that? What was the problem, bad wiring,excessive voltage/amp draw? The video poster named several names, along with statements of cheap imports, but some suppliers were ok,so what is it? The video poster titled the video as tips, what tips? I really got bored with his talk and driving around. If you have something to say, say it and point out the problem, easy.
    I understand the CANBUS system very well and the point he was trying to make never came across.
    As motorcycle owners/riders we like to make the bike our own. If their is a problem share the knowledge, we all like to learn. I spend a lot on my bikes and enjoy them while riding and the tinkering that goes along with it.
    I don't think the video author finished his work and wants me to remove my lights, He should not talk down, but should explain his statements.
    Jun 2016
    I thought his message was pretty clear, Aracknoid.....putting cheap imported gear on your Spyder is false economy, as there is a higher likelihood that it will cause you issues in the long term.......but that's just MY interpretation.
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Idaho
    No lights on the Spyder are connected to, powered by, or controlled by, the CAN bus. The closest are the turn signals. They are directly controlled and powered by the cluster, which is connected to the CAN bus.
    2014 Copper RTS
    Oct 2013
    Pottstown, PA
    Looks good, Bob. I especially like your amber fender lighting. And those bump skid LED's look bright enough to attract some attention in the daytime.
    HERE is what the front of my Spyder with DRL's looks like in the bright sunlight, and at dusk.
    Rob
    2013 RT Limited
    Very Active Member redneck diva's Avatar
    Oct 2013
    Covington, Ga
    we have #182 feet of LED lights on my Spyder & that's not counting what we have on the RT622 trailer.
    light it up...........................................
    Redneck Diva
    Member of the Southern Cruisers Riding Club Chapter #213--
    Central Georgia
    Proud PGR rider
    Jun 2016
    Some shots of my "Safety Lighting":
    Gee Bob, and people have been speculating for years where crop circles come from.....now we know, eh? .......was that taken just before your vertical takeoff?
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Quote Originally Posted by redneck diva View Post
    Gorgeous!!
