rear tire valve stem
When I inflated the rear tire on the spyder the other day, it looked to me that if the valve stem were on the right hand side (side opposite drive belt) it would have been easier. Since I don't have the bike here right now to check, home run is being installed, I'm just asking if it would have been easier.
Hmmmmmmm, consensus would say yes
I asked about that up in Canada and they had no plans on changing it.
I guess a new drawing emailed to China would be to hard
I had the same problem with all the 2-wheelers I have had. Doesn't seem to be the logical place to put the stem, but there must be some good reason. BRP is not the only one doing it.
2008 GS SE5 in 2008
Traded at 43,000 miles for a left over
2010 RT SM5 in 2011
Traded at 57,000 for a left over
2014 RTS SE6 in 2015, which has 35,000 miles
Oct 19th, 2017, totaled 2014 RT while killing a Javaline
Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
Never had any breakdown stranded issues.
I just got back from a ride and filled my tires after sitting over the winter.
For sure, it would have been a lot more convenient on the right hand side, or at least have the stem be an inch longer than it is.
Just an inch longer wouldn't do it; it needs to be angled. I'm going to get a 45 degree valve stem extender.
Very Helpful Member
I think I was in the same group as you during the factory tour. I distinctly remember someone asking that question there and, I agree, they didn't seem too interested in changing it. In fact, they basically blew it off as if they couldn't understand why it would be better if it was on the other side.
I agree that it's difficult to reach on the pulley side but I bet some product liability lawyer suggested it since there's a hot exhaust on the other side. It was obviously intentional.
Thats it.
do they make them?
Originally Posted by smokster
do they make them?
Lots of different tyes of valve extenders available at most autoparts stores....
If anyone ever finds out why they placed this in such a 'user unfriendly' position please tell?
I went to a couple auto parts stores and no luck.
I ordered the 90 degrees from the internet.
Please post how they work out for you.
Thanks
Thanks
It works fine. I put it in one position when riding and when I want to check the air press or inflate I turn it.
?????? Any pics for clarification.
2008 GS SE5 in 2008
2010 RT SM5 in 2011
Post latter.
Reason: edit
Reason: fix it
Slick-where did you get them?
2020 RT Ride Frequent Stay Safe
Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
Backrest Home Brew Mod
2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
[quote=BeRight;87055]Slick-where did you get them?
I got them here-
http://www.rvupgradestore.com/index....Action=GOFETCH
But, I suggest trying an RV store due to the shipping cost of $8.62 for something that was less than $12.00.
Would 45 degrees work well as well ?
RT-S PE#0170
I am sure that this is a stupid question , would the weight of the extender combined with the centrifugal forces cause any problems with valve stem over a period of time?
I think that is actually a very valid question. Maybe someone with some technical expertise could chime in. Do these things extend the existing valve, or replace it? If they just extend it, it seems to me the added weight and stress from centrifugal force could be a concern.
Bruce
Bruce Brown
London, Ontario, Canada
Spyder Ambassador (Ret.)
2009 Moto Guzzi Stelvio "Silvia Dionisio"
Help us fight prostate cancer: http://motorcycleridefordad.org/
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, 'WOW, what a ride!'"
Just throwing this out, how about having the tire refilled with Nitrogen? Thats supposed to keep it's pressure better, reduce moisture, etc. In short less maintainance.
