Results 1 to 25 of 42
    Active Member Dave7691's Avatar
    Aug 2015
    Bethel Ct
    Default Turn signal indicator
    I think this been asked before but I will ask anyway.
    Is there anyway to make the dash indicator brighter for the turn signals .
    I can hardly see mine .
    Blind in Ct .
    2015 F3S , silver
    Very Active Member GaryTheBadger's Avatar
    Jan 2009
    Northwest Arkansas
    This will fix it! They are awesome!!
    http://www.spyderlovers.com/forums/s...ight=turn+muth
    Enjoying now: 2015 Spyder F3 SE6, 1970 Indian MM-5A, 1972 Suzuki RV90J Rover, 2017 Indian Chieftain (wife's)
    Wish-I-had-kept-them: 2008 Spyder GS SE-5, 1967 Shelby GT500 w/Paxton supercharger, 1972 DeTomaso Pantera, 1991, 1992 & 2001 Acura NSX's, 2012 V-Star 950 Tourer, various 2-, 3- and 4-wheelers
    2015 F3 SE6 , White - The fastest color!
    Active Member BamaJohn's Avatar
    Feb 2015
    Talladega County, Alabama
    Default check out Lamonster
    Quote Originally Posted by Dave7691 View Post
    Blind in Ct .
    Me too...have to squint and lean forward to see if the turn signals are on.
    Lamonster has mirrors that mount on the handlebars with turn signal indicators in the housings. This eliminates looking at your hands when trying to use the stock mirrors. The kit also replaces the stock location for mirrors with small turn signals. It's a plug-n-play arrangement with a little routing of wires along the handlebars.
    Can you tell I like mine?
    JB
    John B.
    Current ride: 2020 Spyder RT-s Petrol Metallic Blue dark with OEM top case
    Aug 2008
    Maryland
    Another option from Lamonster Garage _SPYDER F3 SIDE / FRONT BLINKER KIT
    2020 RT Ride Frequent Stay Safe
    Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
    Backrest Home Brew Mod
    2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    In direct response to your question.
    NO there is not.
    AJ
    Blind in Ct .
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Aug 2015
    Bethel Ct
    Thanks for the input
    2015 F3S , silver
    Aug 2015
    Bethel Ct
    While I'm on turn signals why doesn't BRP put the signals on both sides like every other bike I've owned ??? Left on left bar and right switch on right bar . A must be a Canadian thing [emoji23][emoji23][emoji23]
    2015 F3S , silver
    Aug 2016
    Central Illinois
    Default Turn signals
    I am not for sure about Canada but yes for Europe area the turn signal switch must be of this design and some are even non self canceling. I have 2 KTM's and I am forever forgetting to switch them off. They can not or will not change the U.S. ones. Even Harley had to put this design into the Street 500/750 as they are built and marketed internationally.
    My guess is Canada follows the same.
    Ranman42
    Nov 2013
    Oro Valley Arizona
    Blind in Ct .
    I see mine fine through dark glasses and tinted full face shield.
    Maybe glasses are too dark or your "Pilot Light" is getting dim!
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Default Here's how I do it....
    I put a small LED light on each side of the dash area...Left and right and wired them into the turn signals. This way I also know which turn signal is on and they are brighter that the onboard signal....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    NorCal - Northbay
    I have had a bazillion bikes in my time and I've NEVER seen one with separate switches for left and right turn signal activation!!
    Chuck
    Harrington, Australia
    I'm the same as you Hypurone.....
    HeliBars Handlebars
    Kenda Kanine rear.
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by hypurone View Post
    Prior to my first Spyder (2013 RTL) I had a 2010 HD Heritage Softail Classic that had separate switches for left/right turn signals, they were self cancelling, too. That was the only bike I ever had with separate switches.
    2020 RT Limited , Chalk
    Nov 2012
    North Las Vegas, NV
    It's a Harley thing.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Registered Users Bagger's Avatar
    CT
    Default I agree ....
    Pretty lame that BRP has this feature. Tiny little blinker indicator on the left side. Give me a break.
    Harley has had separate switches for Left and Right indicators for over 2 decades. Self canceling as well. So much for the American Iron guys. Yeah, I have one of those as well.
    I don't have a huge problem with the switch ... altho, it is lame .... but, having such a tiny indicator is pretty much a screw up in my opinion. Having self canceling indicators, LARGE Left and Right lamps (like Honda GWs, for example) is just a safety feature. Cost? Minimal. Improvement? HUGE !
    You'd think a $25,000 bike would have something like this. And .... how about that horn?
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    Quote Originally Posted by jaherbst View Post
    Jack
    The OP has a F3s, you have a RTL. Two different dashes. The F3's Are very hard to see!
    2020 RT Limited
    2020 RT Limited , Petrol Blue
    Registered Users StreetBob's Avatar
    May 2013
    Perth, Western Australia
    You never had a Harley then?
    Danbury Connecticut
    Harley's do this.
    All my Japanese bikes and the Spyder have the single switch.
    As to the turn signal indicator on the dash, this seems to be a poor design across all the flavors of Spyder.
    This is what I did:
    IBA #47122
    2020 RT Limited Asphalt Grey
    Quote Originally Posted by Bagger View Post
    The Spyder turn signals are self canceling, but it's like 30 seconds. Twice as long as Goldwing.
    Sent from my SM-T350 using Tapatalk
    Mar 2016
    Astoria, Oregon
    Just finished it this morning.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    May 2013
    Jimboregon, that looks like the answer. Can you give us more info please?
    Oct 2007
    Not on my F3, it cancels almost immediately after the turn.
    Mar 2016
    Highriver,ab.canada
    Default turning lights
    [QUOTE=Dave7691;1186964]I think this been asked before but I will ask anyway.
    Blind in Ct just installed 2 led bolt lights above mirror wired into signal wiring. Very bright in daylight. Orange in Color.
    Mar 2016
    Astoria, Oregon
    Quote Originally Posted by StreetBob View Post
    I bought the kit from Auto Zone, it comes with 2 4" LED stripes. Pulled the mirrors off, drilled a small 3/16 hole in the top corner behind mirror, snaked the provided 24" connecter wire through and spliced into the turn signal wires. Really easy and simple! To do the job you'll need; 3/16" drill and drill motor, 4 solder less wire connectors, wire splicing tool, isopropyl alcohol to clean mirror housing, and about 1/2 hour.
    Mar 2016
    Astoria, Oregon
    The LED kit was $18 at Auto Zone. I wanted amber color, but that company doesn't sell an amber LED, so I bought white. Also, when you plug in the little four hole power cord into the four prongs on the strip, make sure you align the arrow on the plug to the arrow on the strip, or the LEDs won't light!!! I've learned most everything from the School of Hard Knocks!
