Results 1 to 16 of 16
Thread: Oil
    Apr 2016
    East Texas
    Default Oil
    Just wondering if any other 1330 owners have experienced any oil blowing out of dipstick area and dripping on top frame right under dipstick on 2016 F3 Limited?
    Eddirt
    Eddirt
    Very Active Member Eagle1's Avatar
    Nov 2013
    Lutz, fl
    No problems thus far.
    Ryde as if your life depends on it,
    because it does !! Ryde Safe!
    Vietnam 67-69
    Invalid Emails
    Oct 2013
    Dardenne Prairie, MO
    may be overfilled?
    2014 RTSS , Cogna/ black
    Default THIS ISSUE
    Quote Originally Posted by E Reed View Post
    Eddirt
    Someone reported this about 3 (?) weeks ago......sorry but I don't remember who ...........Mike
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default CERTAIN
    are you CERTAIN the dip-stick is seated properly....?
    NO such issues with my F3...
    SPYD3R
    Very Active Member youngers's Avatar
    Sep 2016
    clark county indiana
    Eddirt
    can you tell us more ? has there been oil added , before you noticed this ? or oil change , and the mechanic might over filled ? or maybe the oil cap filler , has no -o- ring and it is blowing by the cap ?
    Sounds like an overfill or a non-seated dipstick. My 2014, has not burned or leaked a drop of oil in 22,000 miles.
    Very Active Member Bam Bam and Pebbles's Avatar
    Nov 2014
    Rural Hall NC
    No blowout or drips on mine.
    Current Ride
    2015 RT-S SM6 Cocaine
    Pearl White
    Diamond R Web Armrests
    Shorty Windshield
    Previous Ride
    2012 RT SM5 The Beast
    Pure Magnesium Metallic
    Apr 2016
    East Texas
    Thanks for the replies. First service by dealer and checked oil level after 1K looked good. Notice some leakage while on ride, cleaned it up and went another 2K then noticed leakage again same place. Dipstick o-ring (green) is in place. Got the filler tube and dipstick cleaned and plan on riding a couple hundred miles today. Will see if it happens again.
    BTW, been reading about the belt vibrations problem and did have some vibration in mine as well up until about 7K miles then it went away... get a little vibration right after increasing RPM then it smooths out!
    Eddirt
    Eddirt
    Very Active Member Tango's Avatar
    Apr 2012
    Florida
    No problems here for me. Tom
    Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
    2020 Petrol Blue Metallic RTL
    Default Little checking..
    When you check the cap is it still in place pressed all the way down..? crank case has to breath the only other thing if oil level is correct is the vent is blocked and it blowing out the dip stick... normally vents to the air box
    ​2012 RS sm5
    Jul 2014
    St. Charles Mo.
    Waiting to hear more. The 1330 engines do not vent through the air box like the v twin. I will guess there is too much oil in the crank case. Been there done that.
    Quote Originally Posted by SPYD3R View Post
    I'd double-check, to make sure that it's fully seated.
    Apr 2016
    Florida
    Default Oil change by dealer
    I just had my 3000 mile service. I took the information that the oil change should be about 5.5 quarts. They said they put in 5 and let it run 15 minutes and it took the full 6th quart. I checked the dip stick when I got home and after it cooled and it was to the max line. Could I be overfilled?
    Nov 2014
    Rural Hall NC
    Quote Originally Posted by Zummyannie View Post
    BRP changed the fill amount to 4.7 quarts I believe. If you put in 6, you definitely have way too much oil in it.
    Edit: Actually it depends on which transmission you have. See the table below, thoughtfully provided by Mr. Denman, for the correct amounts.
    Current Ride
    Pearl White
    Shorty Windshield
    Previous Ride
    Apr 2016
    East Texas
    Took a couple of rides and was still leaking. Took to dealer yesterday and the dipstick was replaced, so far no leakage. The original one looked out of round.
    Eddirt
