LATEST FARKLE #2
I kind of like that. What did you do to prep the surface?
AKA Jud Smales, Four Year Spyder Ryder!
"Quando Omni Flunkus, Moritati"
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Driver & Passenger Gel Pads in Seat
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
Break Stripe Kit from Wrap My Spyder
Looks good!
I first took the mirrors off, then the small lower panels, then took the upper side panels off - you have to do this to get the scoops off - then removed all the small screws holding the scoops to the panels, then took the scoops themselves apart (they are 3 pieces held together by screws). I sanded them with 400 grit sandpaper, cleaned with rubbing alcohol, then sprayed on five coats of Krylon Maxx white Primer, 5 coats of Rust Oleum Universal Metallic Pearl Mist, and 5 coats of Rust Oleum Triple Thick Glaze in High Gloss. Note that I did not paint the gloss black front part of the scoops, as I kind of like the combination of gloss black & white. For the "Can-AM" chrome thingies on the small lower panels, I removed 1 small screw to get them off of the panels, cleaned them with rubbing alcohol, then sprayed them with 5 coats of Krylon Cover Maxx Flat Black combination paint & primer. (No clear coat on these, as I wanted them flat black, not glossy). All of the primers, paint, & clear coat are rated for use on plastic.
The Pearl Mist paint is not quite exactly the same as BRP Pearl White, but it is really close. The clear coat helps to make the color closer to the BRP color. I think it turned out quite nice.
Thanks! Nice Job!
BajaRon Sway Bar
Foam Grips
Shorty antenna
Very nice work, looks great!
2013 RT Ltd. SE5
It wasn't hard, just really time consuming. Taking off the panels & prepping for painting was easy. That was about an hour. All of the priming, painting, etc. is what took the longest amount of time. Then, re-assembling everything on a clean moving blanket so as not to scratch anything was tedious too. All in all, 24 hours start to finish. But I am happy with the result and glad I did it. I think that the looks better now, or at least it makes me feel better.
Dwight,
Good job, looks great!
Thanks for the picture.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
