Riding without windshield
The stock windshield on the 2016 RT Ltd is slightly too tall for me. At the lowest position I'm partly looking over it, and partly through it. At the highest position I'm looking through it. Neither option is ideal for me. So I ordered the Can-Am 5 cm/2" shorter one with the vent, and hope to get it fitted in the near future.
In the meantime I've removed the original shield and have been going on some short rides with no windshield at all, to get a feel for it before doing the 200 km ride to the dealer. It doesn't exactly look elegant, but I'm surprised at how clean and quiet the airflow is. The ride to the dealer shouldn't be a problem. It would, apart from the looks, be an ideal setup during hot summer days.
Glad you are willing to test for solution, now question is you gonna try a booster seat? Just look right over shield all the time The shield makes for great bug guard & helps me in rain. Thankfully I dont use it for much else.
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
I had the same problem. Then at Spyderfest a couple of years ago, I replaced the stock windshield on my 2014 RTL with a vented and tinted F4 Sport and it is almost perfect for me. The only negative is that it doesn't keep the rain off of me as well as the stock did, but I don't do much riding in the rain anyway.
I bought the windshield that has the louvered vents in it. It's 2" shorter than the stock RTL windshield. I see over it when it's fully down, and with the electric adjustment, can block all the wind and rain if needed.
masking tape and a jigsaw with a 20 tpi blade and your tall windshield is now short enough.
why not take the old shield to someone who can cut it down. that way you can get a shield that you like, and still have the best of both worlds with the new one you bought.
NO BIKE AT THIS TIME
If you're riding around with those windshield struts "flopping about"; it might not be a bad idea to find a way to secure them...
Putting an AirHawk-R under your bottom might raise you up just enough, and it would make your butt happier too!
Lots of choices
Cutting it down yourself, or with someone who can, gives you the option of seeing where it works best. Just don't go too far....but nice to know that it is not that bad a ryde with out the sheild at all.
2012 RS sm5
I masking tape the height i want and cut it with dremel with a disc saw. Not difficult it's just the stress you have. when you start cutting your stress will come down and you will be proud of yourself. I finish with some abrasive disc for the edge to make some correction.
Or you could cut longer to practice , you will know how it's will go.
I used to cut the Lexan windshields for my race car with a router. Did a killer job.
Thanks for all the suggestions and comments.
Yes, I could have cut down the original windshield, but I'd still have to add the louvered vent to get an equivalent windshield. On hot days that vent should be very useful, as even with my limited experience it seems the stock shield would not provide enough airflow during summer months. I've also noticed that it's possible to add a vent to the original. But then I'd be getting into the same sort of price range as the new shield. I may even need to trim a little off the new shield to get it low enough.
Bob, there are no windshield struts flopping about. The large (aluminium alloy?) bracket that connects the struts and that the windshield is bolted to is still in place. And there's no way I can move it at all by hand. The motor still works, so I can move the bracket up and down as I ride.
I do have an old airhawk that was used on a 2-wheeler, but it's not big enough for the Spyder seat. The stock seat is comfortable enough without an airhawk, and it would have to be a very thick airhawk to let me see entirely over the original shield.
Good to hear that the shorter, vented Can-Am shield works well.
I forgot that you didn't need to remove the mounting bracket...Sorry!
I bought a short Special Series windshield from a friend and I like it so far. When I put it all the way down its like not having a Windshield at all The standard windshield was suffocating me in hot weather, I'll put it back on when it gets cooler though.
2021 RTL Marsala Dark Edition 4.13.2021
Lamonster Riser
Spyder Extras Docking station
Zumo XT (my own Plug & Play cable)
WrapMySpyder Carbon fiber partial kit.
Baja Ron ultra performance sway bar and end links
2015 RTS SM6 Intense Red
born on date 3/2015 (mine on 9/12/15)
Sold on 4.13.2021 33k of fun.
Remember that you shouldn't drive with the windshield all the way completely down. Bring it down to the stop and then bump it back up just a skooch. This keeps lifting bar from breaking from road vibrations.
Current:
2016 Honda CTX700 DCT ABS (faring model)
Kip Moto SherpaX Cargo Trailer
Wife Has:
2014 Can-Am Spyder RT Limited
2016 Lees-ure Lite Camping Trailer
Previous:
2013 Can-Am Spyder RS SE5, zoom-zoom!
2011 Can-Am Spyder RT-S SE5, Foot Burner - Gasoline Boiling Stinker - Gas Tank Vacuum Puller
This is the same thing that I do. Works great and looks good too.
Current Ride
2015 RT-S SM6 Cocaine
Pearl White
Diamond R Web Armrests
Shorty Windshield
Previous Ride
2012 RT SM5 The Beast
Pure Magnesium Metallic
