Page 5 of 6 FirstFirst 123456 LastLast
Results 101 to 125 of 127
  1. #101
    Vermont
    Quote Originally Posted by acdcking12 View Post
    Could I have a link to this please, so I get the correct one?
    Could someone else chime to post a link.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
  2. #102
    Aug 2019
    Stoughton, WI
    2022 RT Sea To Sky
  3. #103
    Feb 2012
    Spring City,Utah
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  4. #104
    Aug 2012
    Central Coast, CA
    This is the oil I've been using in my Spyders for year now and it's always worked well. Years ago I did a Blackstone Lab test on it and it tested very well.
    I've been buying it via Walmart on line for in store delivery because it was cheaper that way. For whatever reason it's more costly in store, off the shelf, if they even have it in stock. The above link showing Amazon for the same price is relatively new, because for years Amazon was selling it for full retail pricing and not the Walmart on line pricing.
    2020 RTL SE6
  5. #105
    Years ago I use dino Valvoline in my 1986 Nissan Maxima. When the dealer opened up the engine to repair the damage from a broken timing belt he said that was one of the cleanest engines he had ever seen. It had something like 80,000 miles on it. I know this isn't directly relevant to this discussion other than my past experience indicates Valvoline oil is good oil. I need to consider switching back to it from Amsoil.
  6. #106
    Vermont
    acdcking12, Look at post # 32,and 33 for links. A couple of people posted links for the Valvoline Full synthetic 10W-40 Oil, so you can get the correct one.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  7. #107
    Vermont
    Valvoline Oil Up date 8/5/2021 1:26pm
    Hi All,
    I did get the Valvoline 4T Full Synthetic Motor Cycle Oil 10W0- 40 in the grey bottle.
    Thanks for the suggestions on where to find it.
    Deanna
    Last edited by Peter Aawen; 09-01-2023 at 03:03 PM. Reason: Moved Post title into text - many only see Thread titles, and post titles mess with Searching! ;-)
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  8. #108
    Jul 2017
    Woodbine, Iowa
    Does anyone use Valvoline full synthetic motorcycle oil in their Spyder's? I have used it in all three of the Spyder's I have owned with no problems. The OEM XPM kits are so high priced. I just wanted to know if anyone else used this oil. I see Value Accessories sales Pro Plus oil for Spyder's. I don't think it would be any better than Valvoline.
    Last edited by Peter Aawen; 09-01-2023 at 03:04 PM. Reason: Merged repeat threads on same/similar subject/product/question ....
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
  9. #109
    Vermont
    I am using the Valvoline Full Synthetic SAE 10W40 Motorcycle 4 Stroke Motorcycle Oil (this is for the Ultimate Wet Clutch, Transmission & Engine Protection).
    It is formulated for the specific needs of high performance 4 stroke motorcycles, including high temperatures, high RPM's and Wet Clutch Systems.
    Full synthetic formula for the ultimate protection against wear, deposits and corrosion that can decrease engine performance.
    Developed with advanced additives to resist oil thickening and maximize horsepower.
    Outstanding wet clutch protection for maximum powder transfer & Smooth shifting.
    Meets or Exceeds JASO MA2 API SL
    I have been using the above oil since 2014 (in my 2014 RTS-SE-6 SOLD) and I'll be using the above oil in my current Spyder (2023 F3 LTD Special Series). I have not had any problems with the above oil.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  10. #110
    Deanna
    .... I used it for 3 yrs. in my 14 RT and liked it ..... However, Valvoline went up in price by quite a bit ..... I found Rotella T-6 which works just as well and is less expensive .... been using it for 6 or 7 years now ..... Mike
    Last edited by Peter Aawen; 09-12-2023 at 09:00 PM. Reason: Fixed quote display ;-)
  11. #111
    Feb 2012
    Spring City,Utah
    ...... been using it for 67 years now .....Mike
    Wow that long MIke, Boy that's a lot of loyalty. (ooops?)
    Last edited by Peter Aawen; 09-02-2023 at 03:21 AM. Reason: Fixed quote display ;-)
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
  12. #112
    Good catch .... a typo , I didn't add ....OR ....; Mike
  13. #113
    Dec 2019
    Land of Lincoln
    I use and like that Valvoline ....... here's something that might not be known about the Valvoline - Out of about 20 of the leading Mtc oils. This Valvoline had the second lowest Molybdenum added to the product, only Amsoil is lower ........... Moly is BAD for WET clutches .... and the Spyder has a Wet clutch .........Mike
    Oh it's low all right. Zero.
    It is the most unexciting oil period. No moly. Some Boron. Appropriate Zinc and Phosphorus. But nothing to stop overall wear except a group III base stock.
    This constant thing about moly though.... it just isn't so. Many MC oils have moly. Redline, highly regarded, very expensive, POA base stocks, 477PPM Moly. Even factory Honda oils. Yep, those oils used in Wings, CBR's, 12k RPM Honda factory race bikes...499 PPM Moly. It really is more important to look at the overall package the oil provides vs the amount of the single element, Moly.
    Rotella is as boring as the Valvo MC oil. Boron, Calcium Zinc and Phosphorus. On paper, it looks almost identical. Why spend $9 a quart when a 4-quart jug is $16 for conventional or $24 for synthetic?
    Also, Rotella isn't tested for MA approval. Shell just states it meets it to keep MC people buying it because they have been for decades.
    The information is available with a search. You won't find Rotella on the JASO approved list. Only place you will see Rotella and MA in the same place is the bottle.
    There is no magic MC sauce. They all shear; they all get dirty; they all wear out. Some will do slightly better than another, maybe, but your best insurance is clean oil, often enough so dirt is kept in suspension, you stay in grade, and you don't trend acidic.
  14. #114
    Aug 2012
    Central Coast, CA
    As I understand it, Rotella isn't sold as "approved" because they don't submit their oil for very expensive testing protocols to get that approval.
    2020 RTL SE6
  15. #115
    Mar 2015
    forrest above Reno, Nv
    Just completed an oil and filter change on the poor, old, slow V-Max yesterday with the aforementioned Valvoline 10W-40 full synthetic motorcycle oil. purchased on line....
    Lew L
    2014 RTS , Circuit Yellow
  16. #116
    Jul 2023
    Chesterfield SC
    I was just looking at Vavoline web page and it listed Pros and Cons for the 10w40 motorcycle oil. In the Cons side it said you could only run 600 miles per oil change. What in the world are they talking about.
  17. #117
    Quote Originally Posted by Leaping1 View Post
    600 miles - ..... JMHO Mike
  18. #118
    Jul 2023
    Chesterfield SC
    I agree with you, but look at their website.
  19. #119
    Clinton, MS
    Have you got a link to it?
    2019 RTL Phoenix Orange
  20. #120
    Jul 2023
    Chesterfield SC
    Just my luck. Now I can't find the link. But if you search Vavoline 10w40 motorcycle oil it's there, I just can't stumble across it again.
  21. #121
    Clinton, MS
    I don't think you were on the Valvoline website. Maybe it was the Vavoline site.
  22. #122
    Quote Originally Posted by carbonation View Post
    There is no magic MC sauce. They all shear; they all get dirty; they all wear out. Some will do slightly better than another, maybe...
    While I agree with your premise that all oils need to be changed. And while I don't mean to argue here. I think 'Slightly Better - Maybe' could be a bridge too far.
    We have many oil analysis that show the BRP Blended 10/40 (the original) and the current 5/40 consistently shear down to 20 weight between 4,500 and 5,000 miles. Whereas Amsoil typically remains at 34-36 weight at 10,000 miles. I would summit that this is much better than 'Slightly'. And while Amsoil, in our samples, has maintained the best viscosity stability of any oil tested. There are several other oils that do much better than the BRP product.
    Granted, comparing a blended oil (which is probably only 10% synthetic) to a full synthetic oil is not a fair comparison. It does give evidence that there can be a great deal of difference in stability and longevity between products. It's not all Hype and Hyperbole.
    If you are going to change your oil every 4,500 miles. Then the BRP lubricant is going to retain spec. fairly well. But many are running the factory recommended 9,300 miles or farther between service. While no one is blowing up engines. You have to wonder what kind of protection you're getting from 20w oil when 40w is prescribed.
    The debate will never end. And few will change their mind. I use Amsoil only as an example. As mentioned, there are a number of superior lubricants out there. I just feel that real world facts should be the rudder we steer by.
  23. #123
    Jan 2021
    Descanso, CA
    Concur with BR although with BRP and L-M 5W40 I observed (via dashboard pressure gauge) the "knee" at 3K miles. Whereupon I changed oil.
    The viscosity issue, at least for me, is not engine oil pressure (which is allowed to drop to 8.7psi at idle) but rather the HCM solenoids and multiplate pressure-engaged clutch. The HCM has its own oil pumps (scavenge, pressure) with two pressure circuits and the line pressure circuit operates at twice the maximum engine oil pressure. Although I'm sure the TCM has long-term trim to compensate for solenoid and clutch plate wear, my experience is my 95K miles transmission operates more smoothly and consistently with higher viscosity oil (in my case 15W-50). I have the parts to tap into the HCM oil pressure sensor (it's a standard 3-wire 5V transducer) but have been procrastinating.
  24. #124
    Quote Originally Posted by BertRemington View Post
    That would be an interesting gauge to have. Let us know if you actually do it.
  25. #125
    Sebring, FL
    Paul, you were referring to Valvoline as posted BlueKnight Mike, right?
