Results 1 to 25 of 35
    GOS member (Girls On Spyders)
    Sep 2011
    Billerica, MA
    Default Need advice/info on Installing battery tender harness?
    Hello SL Family!
    Although I don't really want to think of it, I do live in New England, and realistically, there isn't a whole lot left of a ryding season. I'd like to install a Battery Tender quick connect terminal,under the seat of my 2016 RTS Special Series, just like I had on my 2010 RT-AC, so the battery will stay charged over winter.
    I tried the search feature, but had no luck. Does anyone have a quick how to? TIA!
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    I think most of the Tender leads terminate in the frunk. somewhere not too far from the battery. Under seat is a whole
    different can of worms, and it probably starts with a Tupperware peel down. Good luck.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    My plug in for my battery tender comes out of the liner in the frunk. I can put the cap on the plug, stick it in behind the liner and zip the liner shut. You would never know it was there. Open the frunk right before I turn the key off and plug it in till the next ride. Easy peasy.
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Very Active Member dlby's Avatar
    Nov 2014
    Indiana
    Same here
    There is a hole with a plug in it near battery
    I leave tender wire out with zipper tight up against wire
    I love R&R put another dime in the jukebox baby!
    May 2016
    Exactly the same here.
    2013 RT-S SE 5
    Jul 2010
    Las Vegas, NV
    Default Battery tender leads
    Open Frunk. Unzip liner. You will see two #30 torx screws. Get your toolkit from under the seat. Remove the torx screws. Lift battery cover panel out to expose battery. Connect red wire of battery tender pigtail to positive terminal. Connect black wire to negative terminal. To the right of the battery is a round rubber plug. Remove plug. Cut from 3 o'clock position to the center with sissors. Pass battery tender wire thru hole, placing rubber cover over wire. Insert in hole. Replace battery cover and torx screws. Bring zipper up to wire on each side, trapping the connection. Close Frunk. To use, open Frunk, plug into bike, plug into wall outlet. Done. Need help? Call! Joe
    Joe Meyer
    Nov 2013
    Central Texas
    I use the cigarette lighter adapter (Wal-Mart sells them online) and plug it into the 12 Volt outlet in the rear storage compartment, which is always hot since I moved the fuse for it. Couldn't be easier.
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    Quote Originally Posted by smurfette View Post
    ...I'd like to install a Battery Tender quick connect terminal,under the seat of my 2016 RTS Special Series, just like I had on my 2010 RT-AC, so the battery will stay charged over winter.
    Yes on your 2016 the battery is in the frunk. On your 2010 the battery was under the seat. Much easier to install on your 2016 and others have indicated how.
    Marilyn 2023 RTL Red
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    "common sense will prevail....but we see no sign of that"
    Registered Users ShortCake's Avatar
    Southeastern PA
    [QUOTE=oldguyinCT;1183424]I use the cigarette lighter adapter (Wal-Mart sells them online) and plug it into the 12 Volt outlet in the rear storage compartment, which is always hot since I moved the fuse for it. Couldn't be easier.
    I live in Pennsylvania and yes, we can have very cold Winters here. I am new to the Can-Am Spyder world and purchased a 2015 RT-S just this past June. I was wondering, the Black & Decker trickle charger I purchased, comes with everything including a 12-volt adapter to use in the rear trunk of the RT. Do I just plug it in and it will automatically work? Or do I have to move some fuses around like you mentioned in your above post? If the power to the 12 volt access only works with the key on, then obviously this will not work and I will have to attach the leads to the battery in the frunk, correct?
    Nov 2015
    Myerstown, Pennsylvania
    Take a look at your owners manual. I forget what fuse needs to be switched. The numbers 6 & 7 I think have something to do with it.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Faribault, MN
    Shortcake, What Steve said, if your '15 Spyder's trunk 12v socket is only (currently) ignition hot, then you should find a fuse in the front right side (left as you're looking into the frunk) fuse box position 6 and nothing in 7, move the fuse from 6 to 7 and the trunk 12v socket should be always hot. Then Batt Tender works always without ignition switch on.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Registered Users Gray Ghost's Avatar
    Harper, Texas
    [QUOTE=ShortCake;1184205]
    Quote Originally Posted by oldguyinCT View Post
    You should be using a battery maintainer. They have the capability to sense when the battery is fully charged and stop charging. A pure trickle charger will constantly send current to the battery which can cause problems.
    Clifford Fargason
    2013 Spyder RTL
    2007 Royal Star Venture
    Registered Users lou49's Avatar
    lake mary fl.
    To my knowledge BRP states on the manual not to connet anything on that terminal under the seat ( why do they put it there then?) open the frunk and under the black cover on the left side of the bike you'll see a positive and a negative terminal use those! that's how i installed mine! whatever works for you!
    Active Member Badco149's Avatar
    MERRIMACK
    Hi does anyone have any suggestions or documentation on how to wire up a 2016 F3 S? I would like to plug in and use the battery tender and if possible just leave connector so I can plug and go. Not to familiar with working on the bike yet. First winter with it,
    Thanks in advance.
    2016 Spyder F3 Limited Special Series
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    Quote Originally Posted by cptjam View Post
    or if youre lazy like me use the squeeze clips to connect to the battery and do like
    he says .--irv
    [joyce & irvin toms]
    Registered Users Ctider07's Avatar
    Jul 2016
    Ranlo N. C.
    Joyce 47 THANK YOU. ... ME. AND WHITE LIGHT ING WILL BE CHARGED. RIDE ON
    Sent from my SAMSUNG-SM-T337A using Tapatalk
    Dec 2015
    Oakley Utah
    Default Battery tender connection
    I'd be concerned about using the outlet in the rear trunk. Some battery tenders are going to exceed the amperage limit of that connector and then you've got a potentially dangerous situation. The connection to the battery in the frunk is much safer and doesn't require messing around with fuse placement (which could lead to battery trickling OUT of the battery leaving you with a dead battery under some circumstances.
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    Moving the fuse from switched to hot for the rear power outlet cannot cause battery drain if nothing is plugged into the outlet. A fuse doesn't drain the battery.
    May 2019
    Canada
    2011 rt limited how do you connect a battery tender to this one
    Oct 2019
    Bakersfield, CA
    I wired the battery tender through the frunk on my wife's 2013 RT but she just got a 2018 and I got a 2019. Wondering if I should go through the frunks again. The only connectors in the top box in the rear on mine is a USB connector, which I could make hot with the fuse switch, but I kinda don't like a lot of distance between the battery and the charger, so I'm leaning toward frunking it again. What I wish is that I could route it out the side somehow, but with all the motion in the suspension, that doesn't seem wise, either. But somewhere I don't have to leave anything open to use.
    Jul 2019
    UK
    Quote Originally Posted by Xander18 View Post
    You just need a couple of tails from the battery posts to a connector of your choice. Keep them shortish and let the connector(s) lie under the seat. I used 4mm banana connectors because it's easy to connect whatever I want to them. Use decent size cable and put a fuse in the positive lead. You can use it as a power outlet or a charger/tender input.
    Rule#2: Never argue with an idiot. He'll drag you down to his level & then beat you with experience.
    Rule#1: Refer to rule #2.
    Jul 2019
    UK
    Quote Originally Posted by PumpkinSpice918 View Post
    ...What I wish is that I could route it out the side somehow, but with all the motion in the suspension, that doesn't seem wise, either. But somewhere I don't have to leave anything open to use.
    I just mentioned this in another post for a different question but I'll post here in case you miss it. You can pick up battery power at the main alternator post because it is directly connected to the battery. The alternator is just behind the left front side panel so easily accessible, negative can also be got from a nearby bolt or screw since battery negative is connected directly to engine ground. Easy enough to run a couple of tails to wherever you want at the side if that's your preference. Always fuse a direct positive supply from the battery as near to the positive connection as is convenient.
    Aug 2018
    NEPA
    I ran my battery tender cord to left side of bike under seat to charge and then be able use electric vest when riding
    tied directly to battery with 5amp fuse installed , the black along edge is velcro to keep in place when riding
    Sep 2019
    ON - Ontario
    I put my tender in the Frank also, I took the tub out and drilled a hole and just raneed it through, covered the hole withat tape, easy access now
    Active Member RTL1330's Avatar
    Dec 2014
    Campbell River, BC, Canada
    Hello, mine is at seat front as it is also used for heated gear. I used a heavier gauge two wire cable ( 10 amp ) Motorola radio power cord with the usual ends. Cable was wire direct to battery and threads down above fuel filler to battery compartment. Had it done when assembling my 2014 RTL. I used the longer end of power cord to make jumper cables so I don't have to take liner etc out of trunk to get at battery. Never needed to jump myself but have assisted others. Just traded my 2014 in on a 2020 RTL and I took prepped cable to dealer to be put on when assembled.
    QUOTE=smurfette;1183330]Hello SL Family!
    I tried the search feature, but had no luck. Does anyone have a quick how to? TIA![/QUOTE]
    2020 RTL - Petrol Blue Metalic / Black, dark model.
    Colour match rear tail cover, Garmin GPS.
    Heated Ultra Comfort driver seat & backrest.
    LED headlamps, LED Front corner lamps and lower front LED lamp.
    Baja Ron sway bar.
    Ride Til You Rot!
