Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
  1. #26
    Ohio
    For those using a "Battery Tender" brand. Are you using the Battery Tender Jr. or the Battery Tender Plus?
    Poasttown
  2. #27
    Quote Originally Posted by cptjam View Post
    Open Frunk. Unzip liner. You will see two #30 torx screws. Get your toolkit from under the seat. Remove the torx screws. Lift battery cover panel out to expose battery. Connect red wire of battery tender pigtail to positive terminal. Connect black wire to negative terminal...
    The dealership installed a Battery Tender Jr. pigtail and included the tender with the Spyder at no charge. After connecting the pigtail the technician simply routed it straight upward an out the top of the battery cover door. In 62K+ miles and some absolutely hellacious rain storms I have never gotten so much as a drop of water into the frunk. The pigtail sits popping through the zipper ready to plug into the battery tender.
  3. #28
    Jun 2019
    Deltona FL
    My 2018 has no liner/zipper.....
  4. #29
    Quote Originally Posted by Spyderman2018 View Post
    The 'lower spec' Spyders don't (or at least 'didn't' ) get the frunk liners.... that was just an added 'something special' to enhance the Limiteds and a few other 'special' models!
  5. #30
    Jun 2019
    Deltona FL
    OK, thanks!!
  6. #31
    Ohio
    I have a follow-up question to the installation of a battery tender for Winter storage. Is there a reason to place a surge suppressor in the line between the tender and the electrical grid? My question isn’t as much about the battery but the damage to the bikes electrical system. I’m not sure if the tenders have a suppressor in the unit, if the spyders fuses will deal with it or if it is needed at all.
    Poasttown
    2019 F3L
  7. #32
    Active Member davehirst's Avatar
    Feb 2017
    Christiana PA
    I have mine under the seat on the left hand side. It doubles as a hookup for my heated vest
    2015 RT S , None Tried one, but took it off. Didn't like it Black and Silver
  8. #33
    Jun 2019
    Deltona FL
    Quote Originally Posted by Poasttown View Post
    Poasttown
    2019 F3L
    Nothing to worry about that. We're only talking about amps here, not volts...….
  9. #34
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    Default 2018 RTL Frunk
    I have the 2018 RTL with Frunk liner/zipper. Mine did not come with a rubber gasket around the top lip where the liner folds over. Anyone else have this set-up or was it accidently left off. Haven't had it out in heavy rain yet, so I'm not sure if it will leak.
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
  10. #35
    Jun 2011
    Kerrville, Texas, USA
    Quote Originally Posted by dlby View Post
    Same here
    There is a hole with a plug in it near battery
    I leave tender wire out with zipper tight up against wire
    I love R&R put another dime in the jukebox baby!
    I know this is an old post, but it was exactly what I needed to see when I was trying to figure out how to get my tender connection into the frunk. (I'm in the slow class.) Thanks for posting and helping me discover what was probably obvious to anyone with a brain. Works great! (This suggestion, not my brain...)
    Regards,
    Bret
    2017 RT-S Orbital Blue
    BajaRon Anti-Sway Bar
    SpyderPops LED Bumpskid, Spyclops II LED, Full View Turn Signals & Belt Guard
    Sena 20S Bluetooth Headsets
    Brake Free Helmet Light
    FOBO Bike for Trike
    Rugged Geek RG1000 Safety Plus Jump Starter/Air Compressor
    Lamonster RAM mount/Techmount TechGripper
    Drink2Go Cup Holders
    UltraGard Half Cover
    2017 RT-S , Orbital Blue
