Results 1 to 25 of 39
    Springfield, MO
    Thumbs up Lamonster Oil Change the easy way
    Last summer I took off the splash pans on the bottom of the Spyder to get rid of some of the heat. I've always changed the oil the same way but now that I have the Corbin bags on it's a bit of a pain to get the bottom plastic off.
    So I decided to see if I could change the oil just by removing the one side cover. Sure enough I could get to the oil filter just fine and I was able to change my oil without messing with any other panels. Took maybe an hour.
    Here's the pics.
    Dec 2008
    Jacumba, CA
    Was giving that some thought after I changed mine for the first time last week (after removing all the panels). The protective plate that attaches to the frame has a hole in it lined up with the engine oil plug. Pop the plug, drain the oil and wipe off what little may end up on the plate. The oil drain on the tank is set up same way. Biggest mess would be taking off the filter, but after all the oil from the engine is gone, the only oil left will be what's still hanging on to the filter. A very small amount that will easily be caught by a rag under the filter. Thanks again, Lamont.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
    Jul 2008
    lamonster is that an extra battery or is that were the 07s had it?
    Mar 2008
    Iron, MN
    His photos have foiled his secrets again...
    Springfield, MO
    Quote Originally Posted by Gary View Post
    May 2008
    Saratoga Springs, NY
    Quote Originally Posted by Lamonster View Post
    Ask a simple ?, get a simple (sarcastic) answer!
    Springfield, MO
    Quote Originally Posted by mike3069 View Post
    My bad.
    Yes I added an extra battery to run the stuff that's on when the Spyder is not running.
    Senile Member M2Wild's Avatar
    Dec 2008
    Ellington, CT and Sandy Creek, NY
    That be the 12V blender or the electric grill?
    Silver SM5 PE# 1274, Hindle Exhaust, Touring Windshield, Caliper Trim, B.E.S.T. 3 Year Ext, Nuvi 255 GPS, Fog Lights, Sport Rack, Back Rest, 12V Outlet, Talon 3300p Alarm, NMN Mud Flap and TipZ LEDs, SpyderLovers Emblems, Kuryakyn Widow Pegs and Axel Trim, Luimoto seat skin, Evo Air Filter and O2 Mod, Cranker Tank Bag, Blue Sea fuse block, MAD/AMS/MBG, Oddyssey battery, IPS.
    Service Bulletin Applied: Gen II parking brake, 2nd SW patch, evap can/hose update, Gen II DPS
    Invalid Emails
    Mar 2008
    OC SoCal
    Lamonster - did the Spyder run cooler with the splash pans off?
    Have you previously posted a thread about this?
    Frank
    Springfield, MO
    Quote Originally Posted by trikester View Post
    Frank
    Driving down the road it dropped the temp two bars.
    Feb 2008
    Oro Valley, AZ
    Here's the pics.
    The "splash pans" you are referencing... do you mean the flat plastic panels directly below the oil filter and reservoir (think there's one on the right side, too)? Any adverse effects?
    Invalid Emails
    Mar 2008
    OC SoCal
    Wow! I'm definitely going to do this, since I'll be riding in the desert this summer.
    I also have the same question; which pieces are refered to as the "splash Pans"?
    Springfield, MO
    Invalid Emails
    Mar 2008
    OC SoCal
    Excellent, Lamont! "A picture's worth a thousand words".
    Apr 2008
    Jackson, MI
    It look like the splash pans were designed to protect some of the components from road debris. Is cooler running a fair trade off for exposing the underside to possible debris?
    Springfield, MO
    Quote Originally Posted by BRPjunkie View Post
    It is for me.
    Dec 2008
    New York
    Lamont, Do you have a water temp gauge that shows degrees? If so, What degrees does it run with the pans on and pans off? Do ya know?
    Springfield, MO
    Quote Originally Posted by brutus450 View Post
    It depends on too many things to tell you one temp. What conditions are you wanting to know about?
    Invalid Emails
    The Berkshires, MA
    FYI... I just finished my oil change and it took 2 hours start to clean up--which is what I would say is normal for us reg'lar folk with standard tools and adequate patience and limited ability to pay attention to detail (Replace washer BEFORE reinserting drain plug...)
    And yes, I used the new BRP synthetic blend.
    We'll see how it goes.
    Active Member Just Doo Me's Avatar
    Aug 2008
    Millbrook,Ontario
    You could always just drill holes in them to allow for some added circulation.
    Invalid Emails
    Apr 2009
    Tampa
    Went to the dealer to get some BRP oil, as no one else had the correct 5w-40 our machines call for, and a quart cost me $12.99. Now, I figuer it cost about what...$70 bucks to have the dealer do the oil change? , and it would cost me $64.95 (takes 5 quarts to fill the spyder) plus whatever those washers etc call for plus my labor, the mess (I'm sure I would make a mess out of it), so to me, it woud make sense to just have the dealer do it.
    Apr 2008
    Jackson, MI
    Quote Originally Posted by Blinc View Post
    4 quarts. Put 5 in and
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Actually, the SM5 takes 4.1 qts, and the SE5 takes 4.4 qts, so you will need a little more than four quarts for either, but not a full five (unless you like oil in the airbox).
    -Scotty
    Apr 2008
    Jackson, MI
    -Scotty
    I think Blinc has SM5, so 4 would be advisable. Owner's Guide says add 3.9 liters (4 qts), but actual conversion from liters to qts is 4.1. Dealer only charges for 4 quarts, so they either plan on not a full drain of system or leave it a little low to prevent air box blow issues.
    Dec 2008
    Jacumba, CA
    Lamont had advised me to just put 4 qts in our SE5. After pouring 4 qts, I thought....OK, I'll put the exact amount called for. Yep. I overfilled it by a finger and a half. Had to suck out the extra. Lamont, next time = 4 qts.
    So far, using the Royal Purple oil in our Spyder, the oil level has not changed in 2000 miles.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
Tags for this Thread
