tired using the cat one time. man my wife was pissed and so was the cat
2015 RT Limited Intense Red Pearl
Originally Posted by RudyB
Old fashioned way wash mit just keep rolling bike ahead you will figure it out.
+1! Only takes one 1/2 wheel rotation to get the whole rear and the fronts where the brake calipers prevent getting the whole wheel in one shot.
Get one of those roller thingees, lift the back, set the wheel on the rollers. In neutral, small dish mop, wheel cleaner and hose. Lift the wheel again, pull out the roller, done.
john
Floor jack
Originally Posted by ES44AC
What is the easiest way you have found to clean up the rear wheel? My hand doesn't fit very well, due to the tight spaces.
I have a mini floor jack that I use to lift the spyder just ahead of the rear wheel on the shock mount. I jack the rear wheel off the ground and turn the key to on so I can release the hand brake. Now the rear wheel spins freely so you can place a wet rag inside the wheel and spin it. Make sure to block the front wheels before releasing the hand brake. The same mini floor jack also works well under the front lower control arms to raise the front wheels one at a time off the ground so they can spin freely. You can clean the front ones just as easily this way. You can find those mini floor jacks at most automotive supply stores. IMG_20160515_1128039.jpg
SpyderLovers Sponsor
Blue brush
That is the one I have, too! Works great.
I like the bikini bike wash, but they skip the rear wheel!
Joe Meyer
Originally Posted by CapeSpyder
can we jack up just the back wheel? using the shock?
Yes,but use a piece of 2x4 between to protect the shock and bracket. Have done it many times and seen it done at dealer
Richard
* 2012 RS SE5 (hers)
* 2013 ST SM5 (mine)
Daughter RSS SE5 2014
Son in law RSS SM5 2013
P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
2 sets of Kumho 175/55R15 front tires
1 set of Hankook V4
1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
Big surprise
I just took my 2015 RT in for its 3000 mile service. When I got home I noticed something different about the bike. Not only had they performed the recommended service but the bike looked like it had been professionally detailed. The brake dust and road crud had also been removed from the wheels. Talk about SERVICE! Two thumbs up for Ingles Performance in Phoenix, NY.
Easiest
The easiest way is have some one else do it. or
coin op car wash.....
