Results 1 to 10 of 10
    Aug 2016
    North Carolina
    Default Right Brake Light not working on F3
    My new roadster has less than 1000 miles on it and today I was told my right brake light was not working. Suspect the bike was never actually inspected at pre-delivery, but that the list of items was simply checked off assuming a new bike would have all working.
    I can assume the fuse is intact as the left brake light works fine. So, what might be the problem? Or, where should I begin the process of checking. My first guess is a connection is either off or at least not making good contact.
    To return this to the dealer for correction is about as much work as figuring out the problem myself, or at least eliminating as many easy answers as I can. Like the actual connection to the brake light unit itself would be the first place I might check, and measuring the voltage at the wire.
    If there are any ideas I would appreciate hearing them. Thanks
    Msmoto
    2016 F3 Limited SS, Garmin 595LM, Sena 10S, Belt Idler Pulley, Custom Cherry Bomb Exhaust
    Previous Spyder No. 003008
    Very Active Member zuni's Avatar
    Mar 2014
    JAX FL
    Quote Originally Posted by Msmoto View Post
    You just need to pull out a couple of push pins to pull back the body panel holding the tail light. This would give yo access to the connector to see if it was properly seated. Alternately you have three screws and one push pin on the underneath side toward the front of the bike to be able to remove the saddle bag completely.
    CJ JAX
    Aug 2016
    North Carolina
    Thank you, Zuni
    Msmoto
    Mar 2014
    JAX FL
    Thank you, Zuni
    Good luck. PM or post if you run across anything or have other questions. Will offfer what I can.
    CJ JAX
    Bossier LoUiSiAna
    Hope it's just a bulb.. Some things just aint made to last
    Aug 2016
    North Carolina
    My service person states he has seen one other where the brake light was not working and will check it out/replace it once I am back in town.
    Msmoto
    Dec 2012
    Murphy, NC
    Default BRAKE LIGHT
    I don't know if getting to the brake light bulb is different for the F3-Ltd but on my F3-S I just have to remove the passenger seat. Check to see if it is as simple as a burned out bulb.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Aug 2016
    North Carolina
    Default LED
    This is an LED unit, the dealership will be checking this out when I return back home.
    Msmoto
    Aug 2016
    North Carolina
    Default FYI....repaired
    My Can Am dealer, Winston-Salem Honda in Winston-Salem, North Carolina, replaced my tail light in about 30 minutes...great service at this dealership.
    Msmoto
    Default Good to Hear.....
    Thanks for following up and posting the problem was solved... sometimes it can be a simple thing but a pain in the butt....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
