The 2017 F3-Limited has 36.5 Gals of storage. The RT has 41 Gals. The trunk on the F3-L is 15.5 Gals alone. Most of the 4.5 Gal difference is probably the smaller F3 front trunk.
Yes, JP......slightly smaller frunk and side panniers.
So from 2017 the F3 Limited storage is fairly similar, Dbaucum, but you still can't get a ful helmet in the frunk or panniers like you can on the RT. (There are a couple of exceptions for helmets in the frunk on the F3, but it has to be a thin helmet)
HeliBars Handlebars
Kenda Kanine rear.
We currently tour on a 14 RTL and was wondering how the cargo volume compares with a F3 with side bags and rear trunk.
I have a 2016 F3 Limited, I had a 2014 RT Limited. There's no comparison when it comes to storage. My frunk will hold my modular helmet and nothing else. One saddlebag is loaded with my rain gear and travel cover. The other saddlebag holds my GPS, gloves and odds and ends. I can roll a lightweight jacket and put it in there, too. All stuff for me.
If you ride two-up, your passenger will need to carry a backpack for their stuff because there's no room for their belongings.
You should consider a trailer along with having two Spyders... Or keep the RTL.
In my opinion, the F3L is not designed for two-up touring.
There's an old saying:
"You can't just put lipstick on a pig; and expect it to turn into a swan... "
"But you can still end-up with a very pretty pig!"
A full size helmet fits fine in the F3 front trunk. I have won more bets at shows with this one. It goes in with the face shield facing up and the base of the helmet against the back wall. I have even dropped a Shark modular in there and those are much larger than a normal full face. My Arai lives in my front trunk with its SENA charger.
The F3s weren't designed from the ground-up for touring; that doesn't mean that it's impossible!
While I agree with you re the F3 not originally being designed for touring from the ground up Bob, the only real differences from 2017 on, from my investigations with the f3 Limited (and I may indeed have missed some) is the electronically adjustable screen (which I had on the Vision and loved), slightly better element protection from the wider panels and slightly more storage. The F3-L really IS a touring machine now, with far more attractive lines than the RT (from my perspective).
Pete
HeliBars Handlebars
Kenda Kanine rear.
But JC, you don't ride an F3-T, which the OP was asking about, with its apparently new front trunk......I can get neither my 3/4 Arai, Shoei Neotec nor 3/4 Schuberth in there.......but then they are all XXL.
Update....just did a check with my wife's Medium 3/4 helmet, JC. It does indeed fit, so if you have a helmet whose manufacturer has the same outside shell diameter for their Medium and Large, you will get a large in there as well. Anyone with a HUGE brain though, who needs an XXL, with have to lock it to the bike......which is impossible with a schuberth with the clip in fasteners.
HeliBars Handlebars
Kenda Kanine rear.
Pete
I have a Shoei Neotec (large) w/ Sena bluetooth and it fits in my frunk. That's the only thing that goes in there. It's too expensive to secure it outside.
I take back everything I said about the Neotec XXL not fitting, Copperman. I forgot I put a roll of double sided Velcro in the trunk lid storage pouch. It does indeed fit once that is removed.
HOWEVER......the Arai and Schuberth XXLs still don't fit ! They possibly would if I was prepared to put pressure on the lid, but having read stories about how the lid can be difficult to open if you close it with pressure, I decided on discretion being a better course than valour
The fact that the Shoei XXL will fit, will hasten my thoughts about getting an XXL Shoei J-Wing however, as I would really like to put my GPS inside my helmet and leave them both in the frunk.
HeliBars Handlebars
Kenda Kanine rear.
HeliBars Handlebars
Kenda Kanine rear.
I just recently traded my 2013 RT LTD for a F3T, and I can say that I do miss the storage that the RT had compared to the F3T. I wish I could of kept both, but I just couldn't afford to do that. I do ride solo most of the time, so it's not as much of an issue for me. The problem I have is, I have no place to store my armored riding jacket when stopped at places, so I just wear it or carry it with me. My helmet goes in the frunk, rain gear in one side case and gloves, hat, water bottle and other odds and ends go in the other case. If you're looking for more of a sport ride the F3 is a fun vehicle for sure. If you're a touring type and ride two-up most of the time the RT is the better choice. I do have my RT622 trailer that I can tow for long distance riding or if I need more storage for stuff. I was able to transfer the trailer hitch that I had on my RT to the F3T. I'm just waiting to get the wiring harness that I need for the F3T to hook to the trailer.
One other thing to consider is, the rear trunk that BRP has for the F3 limited on the 2017 model, will be offered as an accessory for the other F3T's. It's pricey though! $1.400+
Pete
I have an F3S, wife has an F3T. ALL F3 have EXACTLY the same frunk. My Arai full face is a XXL and fits fine, considerable room to spare. Even with the Sena attached. Wife has a Schuberth C3 and it fits fine too, as its actually much smaller than an Arai full face. I admit to not dropping a Shoei Neotec in there unless it was one at a bike show but I have yet to find a helmet that did not fit when placed properly. The shark has to have the modular portion closed for instance. Suppose there may be some that do not fit but the vast majority do.
My shark modular evoline 3 fits in the f3s frunk with the Scala rider 9 attached, back down head hole to the handle bars on a slight angle closed.
Also the shark is the only modular legal to ride open or shut in Australia.
All others are only legal as full face when riding in Australia.
NSW police had a witch hunt on non compliant helmets a few months back (before the relaxed laws were proposed) and booked a few riders.
Reason: frunk auto corrected to drunk
Well there you go. My XXL 3/4 Arai and 3/4 Shuberth definitely don't fit. The Arai is too wide and the Schuberth is too long so you have to flex the frunk lid, which I don't want to do.
HeliBars Handlebars
Kenda Kanine rear.
Pete
This is my helmet(note the size), this is my helmet in my F3 trunk, and this is my trunk closed with the helmet in and no flexing or even touching the lid!
And you still have room to spare for chewing gum, Chapstick and a roll of Tums!
Joe
U.S. Army Viet Nam Era Vet
Utopia Deluxe driver backrest
LED fender lighting
Fast Flash LED brake light
Spyder Pops LED/skid plate
I've got the Schuberth M1, Michael, with the integrated SRC system. I can only assume that the SRC system adds some extra length, or the full length visor does. I suppose, when you think about it, the 3/4 visor is straight, while the flip face or full helmets have a shorter visor and a curved chin bar which might account for the difference in making contact with the frunk lid.
I'll do a little measure of base length between my Shoei Neotec (which fits) and the Arai and Schuberth M1 when I get home. It's a pain not being able to get the Schuberth in the frunk, especially when you can't lock it to lid locks because it's got the European clip style strap fastener.
HeliBars Handlebars
Kenda Kanine rear.
