Results 1 to 13 of 13
Thread: Screen reboot
    Jul 2015
    US
    Default Screen reboot
    I picked up a new 2016 RTS on 8/27. I put 400 miles on it the first weekend. Will put it over 1k by the end of this weekend. As I was riding today, about 7 hours, my screen went blank, then booted back up again, complete with the Can Am logo you see when you start it up. This happened at least 3 times while I was riding. I looked down to check my speed, and watched it reboot. It was pretty hot today, and I noticed it more after we had been sitting in traffic a few minutes prior. Could it have gotten too hot? Has this happened to anyone else? Is this a warranty issue? Thanks in advance for chiming in. I appreciate your thoughts.
    Sent from my SM-N910V using Tapatalk
    on your new . For now, I would say maybe due to heat issues OR loose battery connections. If the problem persists, it should be checked over by a dealer.
    May 2015
    Oregon, USA
    Definitely a warranty issue, and you should take it in for them to fix.
    -Fratz
    Default Here's the thing....
    If the sun is beating down on the screen it may fade away to a blank screen then come back with cooling or shade but the machine continues to function properly. I often pull the safety card to cover on the RS. If that is not the cause then you may have a faulty instrument cluster...congrats on the new ryde...
    ​2012 RS sm5
    If it was the heat: the screen wouldn't go back to "Re-boot"...
    This is probably just a loose wire, and your Dealer should be notified A.S.A.P.
    Nov 2013
    Oro Valley Arizona
    ​US is a poor description of where you live unless your running from the Law or IRS. Some times posters can give advice depending on where you live such as dealer locations, parts or any other information needed. Just my opinion and trying to be helpful.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Invalid Emails
    Oct 2015
    Franconia, PA
    Default Battery wires
    I had the same problem in my 2014 STS. Tightened the battery cables and it hasn't happened since.
    Jul 2015
    US
    Quote Originally Posted by jaherbst View Post
    Jack
    Between Griffin and Douglasville, GA is where it occurred. Between 4:00 and 6:30 PM. Stuck in traffic a bit. Temps in the 90's. Real feel was 100. I was facing the sun, so it wasn't hitting the screen. Will definitely check battery cables, and if that's not it, then back to a dealer. Thanks again everyone.
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    Was it your instrument panel or the GPS screen (both boot up with a Can-Am logo).
    If it's the GPS you can clean the contacts gently with a pencil eraser or electrical connection cleaner.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    United States
    I had the same thing happen Saturday. It was really hot. Rebooted twice on me. Gonna watch and see what happens. I have 2016 RTS with 5500 miles now. I also have had the cruise control kick off. Once with the engine light coming on. Hoping these are just anomalies and don't recur...
    Jul 2015
    US
    Doc Riverside came to the rescue again. Doc was doing some electrical work for me and discovered the battery wasn't secure nor were the terminals tight, amongst other things that weren't done properly by the dealer. I highly doubt I'll have that problem again. Thanks Doc for putting up with me and ALL the work you do on my Spyder! I sure am glad you're close!
    Jul 2010
    Las Vegas, NV
    Default Terminals
    Remove and clean the connections on the battery terminals. Reinstall tightly. 90% of the time it is something simple. If that's not it, take it to the dealer.
    Joe Meyer
    Very Active Member tehrlich's Avatar
    Jul 2015
    Spicewood Texas
    Like others have said, it is most likely your battery connection.
    Happened to me yesterday, and sure enough, the positive terminal connection was just loose enough. Tightened it down and resolved.
    2015 RT Limited: Fox Shocks - RonJon swaybar and links - BRP Comfort Seat - BRP Triaxis handlebars - Yokohama tires (26psi fronts 28psi back) - Centramatic wheel balancers - BRP belt tensioner - BRP Short windshield - CATdelete/Spyder1 attitude exhaust - Lamonster footpegs - sintered brake pads - LED TRYCLED lights - BumpSkid
    2015 RT Limited , black
