Results 1 to 19 of 19
Thread: Is this bad ??
    Active Member Diamond Dave's Avatar
    May 2015
    TX
    Default Is this bad ??
    300 miles from hm and this happened....
    More importantly how could that have happened
    Bryant, Arkansas
    Is that the shaft for the after market trailer hitch that goes thru the wheel???
    Cruzr Joe
    Jun 2013
    queens ny
    what is is, is it your center axial?
    NO BIKE AT THIS TIME
    Bossier LoUiSiAna
    Quote Originally Posted by Diamond Dave View Post
    ? What happened to make you notice? It looks bad but added info will help, I see aftermarket hitch the bolt looks bit thin to be the rear axel bolt but maybe a hitch bolt that goes thru? Are things bent & clanking around? Your belt looks to be on track enough. More info please. (Did you instal hitch yourself??)
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    May 2015
    TX
    This is the main axle bolt fortunately my wife following me on her bike pointed it out .
    Guess I'm going to the hardware store to get a washer and a Cap nut
    Very Active Member Ron2andia's Avatar
    Jun 2012
    Phila
    Wow that's unbelievable.. Glad it didn't cause a major issue for u..
    Live, Love, and Ride! God Bless!
    May 2015
    TX
    Hitch came on the bike
    May 2015
    TX
    Torque specs ? Not that I brought wrenches or a torque wrench , but I can get it close enough for this trip .
    But on the bright side: it's been caught, and is being fixed!
    (You owe your lovely Bride an expensive dinner, and some roses!)
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    When you put it together, if possible, put a jam nut on it, if you can't do that, use blue Loctite.
    john
    Active Member Many brands's Avatar
    Aug 2016
    Atwater, California
    Default axel bolt
    I have never had the axel bolt off my RTS - but have changed many other wheels on many other brands, and NEVER saw any axel bolt that small. The Picture looks like it 3/8 inch. Just can not believe such a small axel nut - for that amount of weight, wheel width, and torque. Going out now, to look at mine.
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    That looks like the hitch bolt to me. The axel shaft is much thicker on my 11 RTS
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Default Wow...!
    close call... push the bolt back through and check the threads and get a lock nut if it does not have a cotter pin hole. You might have the belt checked when possible looks to be running to far to the middle. If you back her up and stop and check its positon and it has not changed your good if it walks off a bit on the sproket it needs to be adjusted...
    ​2012 RS sm5
    minnesota
    That's just a bolt for your hitch. The big nut for your axel is still in place. Had your axel come out that far while you were driving you'd be calling a tow truck and maybe an ambulance.
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    Default is this bad
    That is the through the axle bolt that keeps the attachment plates for that aftermarket hitch in place. You'll need a flat, lock and the nut takes a 17mm wrench. Put blue locktite on the threads and snug it down with your hand on the shaft of the wrench, not the end of it. There are no official torque specks for this aftermarket hitch.
    The axle bolt for the rear axle is 150 ft pounds of torque.
    You will also want to replace the pointy end allen head set screws on the bottom of those brackets with a hex head 8mm bolt that is twice the length of the set screws.
    Keep an eye on your hitch when towing for up and down movement or play; if found will need to shim those attachment plates for your hitch.
    Get a green manual on line for your maintenance needs, will be priceless to help you through your tinkering.
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Bossier LoUiSiAna
    Glad to hear is an odd one for sure glad it was spotted befor damage. If not too out of way Id suggest finding a dealer to help get secure & double check few things Let us know how it goes
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    May 2013
    Stanton, ca
    That is NOT the main axle bolt! If it was, trust you would not have been going anywhere.
    That is the trailer hitch bolt that goes through the main axle bolt. Chances are whoever installed it when they put the nut on the other side they did not get the cotter pin through the bolt. Thus the hitch bolt nut came off.
    Bob
    2011 RT-S SM5 - Black
    Active Member trikerbiker645's Avatar
    Apr 2016
    wi
    It appears to be the thru bolt for aftermarket trailer hitch, looks like mine which is by show chrome. If it is it doesn't use a cotter pin, just has a big washer and nut and you tighten it down. I use blue locktight in those situations. safe riding!
    Baja Ron sway bar, Spyder Dock, Highway Brackets,Trident pegs, Spyder Decals, Signal Mirror led strips, Utopia backrest, 5 pc. Hopnel liner set, cargo nets side/rear doors. Mesh bag front trunk, foam grips, spare trunk key, passenger armrests/storage pouch's, ram mounts/GPS, Drink holder,Phone, Passenger clamp-on drink holder, rear trunk tap light, custom plate frame, spyder fastener bolts, adjustable lower mirror wind deflectors, F4 Customs windshield -wide,tall,clear,vent,Chrome Spyder grill.
    Nov 2013
    Central Texas
    Quote Originally Posted by M109Dreamer View Post
    It is the hitch bolt. The nut on the right side must have vibrated loose. Gotta be really tight.
