GPS gasket part number?
The GPS mount is held in place by 4 screws that go through a slotted rubber grommet (groove around the outside). I lost one installing my Kradellock. This is the same style grommet (but different size) that go through windshield.
I don't even know the name of these grommets and my google searches haven't come up with a similar part (grooved grommet, slotted grommet, grooved washer, etc). Other than use two small grommets - one on the outside of the mount and one on the inside, I haven't figured out to replace this ...thing.
Has anyone got a vendor/part number? I'm always amazed at how this forum always yields SOMEONE who knows this stuff.
2020- RT Limited
Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Big Bike Parts wiring harness
Permanent Smile!!!
It looks something like this...
2020- RT Limited
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Permanent Smile!!!
Go to Lowes or Home Depot and look through their selection of screws, bolts, pins, grommets, spacers etc, etc drawers and see if you can find one that matches one of yours.
intelligence is genetic. Stupidity is an acquired skill.
If you are looking at this part for a 2014 RT Limited then there does not appear to be a gasket or O-Ring there.
The Power of Logic.
Start Thinking.
The diagram you've found doesn't appear to be in the area I'm discussing - I couldn't find an exploded diagram of the GPS mount itself.
This is the GPS mount which is held by 4 hex-head screws to two u-shaped connectors that swivel front to back.
2020- RT Limited
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Permanent Smile!!!
Those are garmin parts and come with the garmin zumo motorcycle mount kit. (BRP repackages the Garmin mount with a BRP produced bracket) Garmin does not have a sepreate listing for those grommets but you might call them.
You're correct, those are Garmin parts. But, so far they are re-directing me back to BRP.
I'm going to try jegerh's advise of looking in the parts bins for automotive at Lowe's and/or Home Depot and see if I can get close.
Thanks all for the advice.
2020- RT Limited
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Permanent Smile!!!
Afters several years on a Harley two of mine disintegrated from the Heat out here.
Those "parts" are NOT available from Garmin.
Like previously posted went to a hardware store (Ace) and bought a suitable grommet/washer to do the job.
Why they make a neoprene grommet that will deteriorate over time ???
AJ
2014 RT-S
Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
In my next career as a motorcycle designer, I will have no black holes where parts can fall in and become completely irretrievable.
Last week I found a screw in a groove of my driveway. It was one that fell in a hole a year or 2 ago.
2020- RT Limited
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Permanent Smile!!!
There is s separate Garmin OEM product support number, 855-607-2536. If you have not called and spoken to one of those techs I suggest you do so as they might be able to help.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Thanks, I'll try them.
2020- RT Limited
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Permanent Smile!!!
The grommets are a part of Garmin Part Number 010-11270-03 motorcycle mount. Its a generic mount, not a BRP part.
