VSS issue. Help!
2014 RT. We are towing our trailer and we are getting a VSS code solid light. Book says to tow it to a dealer. We have no problems while riding. Is this something that can wait for a few days? Do we need to really tow it? Is the bike just going to shut down?
Park the bike.get all keys away from bike. Get away from bike at least 50 feet. Wait about 20 minutes and start bike. Maybe this will fix it. Worth trying.. Good luck and stay safe.
Bummer...
sometimes it is only the angle that will toss you a warning. this is a start to see if it will clear and store the code but if all is operating normally and it does not go to the orange screen and limp home mode you should be fine. I have had the vss kick in on several sweeping banked turns and all was fine but the nanny did not agree. If the warning does not clear you could stop by any dealer and have them clear it with the buds system and see if anything is wrong.
2012 RS sm5
The magical key walk is a myth. A very popular myth but still a myth. It is a total waste of time and effort. What is actually true is if you turn the key off for 30 seconds some types faults may change from active to occured. No need to remove the key at all.
2018 F3 LIMITED
Get the fault code. Press Mode, Set and Turn Cancel at the same time. The code can tell you where to look. Maybe something as simple as the pillion switch becoming unplugged.
2018 F3 LIMITED
Pragmatic Member
What exactly does that accomplish?? Please explain.
Pam
- 2015 RT-S Special Series / Red & Black
- Baja Ron Sway Bar
- Utopia Backrest
- F4 Customs tall and wide vented windshield
- Stebel Super Loud Air Horn
- Baker Built Air Wings
- LaMonster Highway Pegs
- SpyderPops Exhaust Block Off Plate
- SpyderPops KOTT Grill
- SpyderPops Belt Guard
- Cat Bypass
- Laser Alignment by Squared Away
- TricLED Fender Lights
- General Altimax RT43 rear tire
- Dual flag holder
- Mud Flap
- A$$hole seeking missile system
Make sure the passenger seat sensor switch is plugged in. If it's not the VSS icon stays lit.
Sent from my SM-T350 using Tapatalk
2014 Copper RTS
Pam
I don't know why it works. I have had to do it 2 times and it worked for me.
Pam
NOTHING
turning the bike off and allowing the computer to reset will generally clear some problems, and removing the key while it resets is an accepted practice.
Cruzr Joe
Pragmatic Member
Originally Posted by Cruzr Joe
NOTHING
Cruzr Joe
on the computer reset. The need to remove the key is highly questionable. But walking 50 feet away with the key? That defies logic.
Pam
- Baja Ron Sway Bar
- Utopia Backrest
- Cat Bypass
- Dual flag holder
- Mud Flap
Ozzie Ozzie Ozzie
Pragmatic Member
- Baja Ron Sway Bar
- Utopia Backrest
- Cat Bypass
- Dual flag holder
- Mud Flap
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
VSS issue. Help!
Originally Posted by Peter Aawen
No Pam, there IS logic there, it's just that you aren't looking at it the right way!!
By pulling the key & walking at least 50 feet away it means that you are now too far away to kick or punch the bike in anger or frustration, &/or maybe even torch it cos this is the third DESS failure you've had today!! Furthermore, by walking off with the key in your hand, you can't sit there on the Spyder slamming the key back & forth in frustration until it breaks off in the slot!!
So like I said, there is good reason & logic behind walking away with the key, just not the reason that comes to mind immediately for most people!!
My understanding of the Logic is most pistol ranges are set at 50feet. Those with CC permits ,isn't that the range when an possible attacker legaly becomes a Threat?
I wasn't there but I still care! POW /MIA VETS
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
