Check Engine light
Have an issue that the check engine light is on. Code PO175 showed when I checked. I called the dealer and they said bad fuel. Ran with light on until under a half tank. Dealer said to add SeaFoam in the tank with fresh gas. The light is still on . I have taken it to the dealer 4 times this year. I just hit 5,300 miles. Time for a trade I think. I have a 2011 RTS. Any feed back? What's wrong with this Spyder?
This may help you.
https://www.yourmechanic.com/article...-blake-griffin
2008 GS SE5 in 2008
Traded at 43,000 miles for a left over
2010 RT SM5 in 2011
Traded at 57,000 for a left over
2014 RTS SE6 in 2015, which has 35,000 miles
Oct 19th, 2017, totaled 2014 RT while killing a Javaline
Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
Never had any breakdown stranded issues.
Maybe you should try a different dealer to properly diagnose the problem and resolve.
Love my Spyders
2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
2014 RTS Circuit Yellow purchased 3/2/2018
2020 RTL Petrol Blue purchased 1/27/2023
Girls on Spyders #3195
No more 2 wheels
2020 RTL , Lamonster floor board riser Petrol Blue
p0175 is system too rich cylinder number 2. this usually points to a fouled or failing o2 sensor on the rear cylinder. i would suggest new plugs and ignition wires at the same time.
Problem
My Spyder was at the dealer for 5 weeks and they could not figure out check engine light.
I told them to replace the 2 map sensor hoses. They did and light out and it ran perfect.
do a search on this site for
Vacuum hose failure
Map sensor tubing
Than go to NAPA and buy Silicon hose #H466 about $10.00 and replace the 2 vacuum hoses cut to the same factory length. For $10.00 you don't have much to loose as they go bad.
Jim
Have to agree...
....here is what happens and they do get worse
20150726_160929.jpg I would start here then on to the o2 sensor....
2012 RS sm5
Vacuum hose failure
Map sensor tubing
Jim
Agreed, and continue with the Seafoam. You have a severely under-used Spyder. Not uncommon to have a sticky / dirty injector at all. Give the stuff some time to work. Search the forum for P0175.
Doug
”Freedom is not a loophole”
