Results 1 to 5 of 5
Thread: Question?
    PhotoShop Master
    Jun 2008
    methuen ma/salem nh
    Default Question?
    RS model around 2010 semi auto battery died stuck in reverse ...how do you get it out of reverse .... Friend just got his wife Spyders .... Haven't looked at it always know where to get great info ...
    oh and GOOD MORNING SPYDERLOVERS
    I haven't seen you in a while... Glad that you stopped by!
    Under the LH side of the bike, up near where you can get to the oil tank: you should see a hexagonal rod that is hooked up to the "shifting bits". It was designed so that you could put a wrench on it, and shift the transmission... (Although I forget which way you might need to turn it... )
    Good luck!
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    my rt has what looks like a shifter shaft . can we do th same thing
    if God forgive, we ever have to ? irv
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    PhotoShop Master
    Jun 2008
    methuen ma/salem nh
    Thank you brother I'll take a shot ...
    'been so busy not much time for anything lately
    take care
    Good luck!
    Jul 2011
    Mitchell, Ontario, Canada
    Use a 13 mm open end wrench. There is one in the toolkit. Put the wrench on the flats on the back of the shift lever.
    But why do you need to get it into neutral at all? It will roll in gear. When you charge, change or boost the battery and start the engine. It will shift into neutral on it's own.
    2018 F3 LIMITED
