Results 1 to 14 of 14
    Apr 2012
    Arizona
    Default What actually IS ECO mode??
    What is it? Have heard it is just a when to shift mode or a different driving mode. Which is it?
    Very Active Member GaryTheBadger's Avatar
    Jan 2009
    Northwest Arkansas
    It's a way to save fuel if you don't need all-out performance. It makes the throttle a little slower to respond. I use it about 95% of the time, and when I switch out of Eco mode,
    it's like getting more free horsepower! You activate or deactivate it by holding the Mode button for two seconds. There's an indicator in the instrument panel that tells you when you
    are in Eco mode.
    Enjoying now: 2015 Spyder F3 SE6, 1970 Indian MM-5A, 1972 Suzuki RV90J Rover, 2017 Indian Chieftain (wife's)
    Wish-I-had-kept-them: 2008 Spyder GS SE-5, 1967 Shelby GT500 w/Paxton supercharger, 1972 DeTomaso Pantera, 1991, 1992 & 2001 Acura NSX's, 2012 V-Star 950 Tourer, various 2-, 3- and 4-wheelers
    2015 F3 SE6 , White - The fastest color!
    Default Don't know. ..!!
    When they first installed the feature on the 2014 RT's it did not make enough difference to be worthwhile....be interesting to see if it has gotten better....
    ​2012 RS sm5
    Active Member Stangman35's Avatar
    Jun 2016
    Ladoga,Indiana
    It takes all of the fun out of the bike. It's a super nanny.
    I for one will never use it.
    Sold - 2021 RT Limited, Petrol Blue, trailer hitch.
    Traded in - 2019 F3 Limited, Blue/Chrome: with
    Baja Ron swaybar, 19” tinted Freedom Windshield, Lamonster LED headlights, IPS Fog Light Kit, trailer hitch, Lamonster Mirror Locks, Ultimate TallBoy Seat.
    Sold - 2014 Time-Out Camper
    traded in - 2017 Kawasaki ZX14R
    Sold - 2018 Honda Goldwing Tour DTC
    Sold - 2017 Indian Roadmaster
    Traded in - 2016 F3T
    And a couple hundred other bikes over the years!
    Bay of Plenty New Zealand
    Default ECO Mode info
    Quote Originally Posted by MrBones View Post
    SHIFTING SUGGESTIONS:
    (The shifting-point suggestions for the 1330 and 900 series engines are explained separately.)
    Shifting the 1330 models:
    The “ECO” mode shift coach suggests shifting at the following rpm’s:
    1st to 2nd: 1,800 rpm’s
    2nd to 3rd: 1,950 rpm’s
    3rd and up: 2,200 rpm’s
    When manually shifting the 1330, it seems too many are over thinking it. If you are not using the ECO-mode, then just shift at around 2500-3000 rpm’s. That shift-point falls right at the beginning of the first-level power band, which is perfect. (Funny how that seems to work! See below.)
    1330 Engine Power Band (Dyno-Chart Data):
    1st level power band begins at approximately 2,500 — 2,700 rpm’s and remains flat until 4,000 rpm’s.
    2nd level power band begins at approximately 4,500 — 4,700 rpm’s and peaks at 5,000 rpm’s.
    After 5,000 rpm’s the power declines slightly until reaching 6,000 rpm’s; where the power rapidly declines; thus proving any increase in rpm’s above 6,000 rpm’s on the 1300 is inefficient and fruitless with regard to obtaining additional power and torque.
    What does this mean?
    It means shifting below 2,500 rpm’s can put an extra load on the machine when accelerating above a relaxed pace. While it may appear the engine has plenty of power below 2,500, it, in fact, is not producing peak performance power at that point, thus, shifting below the power band makes the engine work a bit harder. While the manual suggests shifting below 2,500 rpm’s, it is doing so with the thought the operator is accelerating at a very relaxed pace.
    Some have a misperception with regard to shifting a machine within its peak power band. It is often perceived to require harder/faster acceleration; when, in fact, that is not the case.
    It simply means you hold the machine in a gear longer before shifting. One does not have to takeoff from a dead stop like a drag racer to shift within a vehicle’s power band. Again, you simply hold it in each gear for a bit longer until the rpm’s reach the power band.
    American’s have long been known to have a preference to low-torque machines. With that often comes the tendency to want to shift to a vehicle’s highest gear as soon as possible, and leave it there… at least until the engine begins to shake and shudder. Not a good idea with any vehicle.
    Why is this important?
    Over a short period of time and mileage, there would probably be little noticeable affect or damage to a machine operated below its power band under normal, relaxed conditions; however, over a longer-term, there certainly can be a excessive wear along the machine’s drivetrain.
    In addition to seeking peak vehicle performance, expert/professional drivers & riders always operate their machines within its power band at all times for added control and handling. Consider it a safety precaution.
    Any vehicle operated outside of its peak performance band is operated with some loss of control and efficiency — varying, of course, to the degree it is operated out of its power band.
    For most owners of the 1330 engine, its lower torque seems to satisfy the inherent American “need” for an engine operating at a lower rpm.
    NOTE: There is NOT a “Trailer Mode” for the 1300 model.
    1330 "ECO" ShiftingCheck your manual) (Provided by PMK)
    The ECO (fuel economy mode) setting reduces fuel consumption by limiting throttle response and maximum throttle opening to maintain an optimal cruising setting.
    Activating the ECO Mode:
    Press the "MODE" button for 2-seconds while in the Main Screen.
    When activated, a green arrow will alternate with the gearbox position indicator to indicate the optimal timing to up-shift the transmission.
    NOTE: The Gearbox indicator will return when the transmission is shifted.
    De-Activating the ECO Mode:
    ADDITIONAL INFORMATION: (provided by Lamonster) The throttle map changes to a more progressive acceleration; rather than a linear one. During hard acceleration there will not be an indication to shift -- the ECM understands you are accelerating and will not recommend a shift at this time. Only when the vehicle speed and acceleration have stabilized for a certain time and the ECM judges there is enough engine torque available in the next gear to keep the same speed and acceleration will an upshift indication be displayed.
    Very Active Member Ron2andia's Avatar
    Jun 2012
    Phila
    Thanks for that info!
    Live, Love, and Ride! God Bless!
    Active Member monkeyboymorton's Avatar
    Sep 2015
    UK
    There's a graph on here somewhere, but ECO limits you to 60% max power across the whole range of the twist. So in ECO 50% of the twist only gives you say 35% power. 100% twist (throttle opened as far as the rider can) only gives you 60% power.
    I have only found it useful in slippery conditions (heavy rain/ice/snow) as it 'damps' down the throttle resposne and so helps stop me getting unwanted wheel spin.
    | 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
    Think of it like this:
    Imagine that you were a World-Class Marathon runner, and somebody made you wear snowshoes, instead of your usual running shoes...
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by Stangman35 View Post
    But then your a manly man doing manly things in a manly manner on a manly road! We are going to call
    you "Manly Marvin" from now on.
    ​Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    I consider ECO mode much ado about nothing. Tried it faithfully for one full tank of gas. Not much more than a gallon increase in mpg. Found that looking for the shift point arrow to be much to distracting.
    I now use the KISS method of shifting. Shift by ear--the 3000 - 3500 range works okay for me. I let it downshift by itself 98% of the time. My mileage--still 39 - 41 per gallon. I am okay with that.
    Rant time: I would rather have the automatic frunk release than the ECO mode setting.
    Quote Originally Posted by jaherbst View Post
    ​Jack
    Apr 2012
    Arizona
    Thanks guys! Quite a response and from what I gather ECO is not that important! So will quit using it.
    Nov 2013
    Oro Valley Arizona
    Right arm farm out Bob!
    ​Not the man I use to be, Jack
    2015 BMW R1200R LC
    I thought that "The Princess" told us that you were getting better...
    Even thought her eyesight might not be quite as good as it once was!
