Results 1 to 13 of 13
    Active Member Harmony 44's Avatar
    Jul 2015
    Saratoga New York
    Default 2015 RTs shift quality
    Has anyone noticed their shift quality change over time? The reason I ask is in May, at 2500 mi I brought it in for its first service and was informed the hydraulic control unit assembly needed to be replaced because of shifting codes (was very abrupt up shifting). When I picked it up it was a whole new bike, much smoother. Well after a busy summer I can find the time to ride again, at 5000 mi I again have abrupt up shifts. When I first start out, shifting at 2900 rpm it is smooth as silk, above that and it is very abrupt unless I blip the throttle, once it is hot it is only smooth by blipping the throttle. What is different this time is downshifting, off throttle seems normal but any downshift with throttle say going up hill looking for more power is abrupt with a sharp metallic clank. It is going back to the dealer this week and hopefully is not too serious, but I think I have an underling issue in the transmission that hasn't been discovered yet.
    I almost forgot, It also has a vibration in the floorboards and handlebars all the time. Not too bad at idle but enough to make my feet tingle at speed, and put my hands to sleep, it never did that before. This is different than the belt vibration from 72-80, but possibly related to the inner sheave, after the alignment it touches from time to time.
    2015 Rt S Se
    Nov 2012
    North Las Vegas, NV
    Might be advisable to have them check the front drive pulley.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Default Well....
    There have been some posts about the sensor cracking and leaking and sending the wrong message. I would have them check this out cause if they replaced it with the original part it may have failed again. I think the 2016 have a different part number and may be a modified part.
    ​2012 RS sm5
    Jul 2015
    Saratoga New York
    Interesting, I'll hopefully have any idea what's going on by Wednesday. Right now I am glad the dealer has done all of the work to this point, this is the first vehicle I haven't touched.
    It may be in my head but I swear it is louder, more guttural when I accelerate. My wife says it's louder with a high frequency whine while on the highway that she can hear as the passenger.
    2015 Rt S Se
    Jul 2015
    Saratoga New York
    Well still no closer to knowing what is going on. Dealer said it seemed normal, and it did feel pretty good when I stopped in. I have driven it abut 300 miles since and the vibration and noises are greatly reduced, the shifting is still acceptable too. As a matter of fact, for the first time since I have owned it I can make up shifts at any rpm as smooth as can be, before anything over 3000 rpm and my wife would bump my helmet. I even tried some wide open shifts and they were smooth as well. The tech just told me to keep looking for metal on the dipstick, fingers crossed it stays this way.
    2015 Rt S Se
    Something does not sound to be quite right. Most of us find the ideal shifting point (smooth as butter upshifts) at around 3000 - 3500. Downshifting done by the seems to be right on around 98% of the time.
    Let us know what happens.
    Quote Originally Posted by Harmony 44 View Post
    If a Technician said that to me: I'd start getting worried...
    Jul 2015
    Saratoga New York
    As a fellow mechanic I knew exactly what he was saying, there is a problem, but to find it under warranty protocol isn't an option. When it is really acting up or finally breaks it can be fixed, until then I will ride the wheels off of it, well as much as I can. If it was not under warranty I would have opened it up and inspected every part, but that would be foolish at this point. All I know is the more I ride it, the more I like it.
    2015 Rt S Se
    Jul 2015
    Saratoga New York
    It surprises me sometimes when the gear change is almost unnoticeable, it is awesome, unfortunately that would be 1 in 20 shifts. Downshifting has always been much better, either automatically or manually, when they started to get rough I knew there was still a problem. Deep down I knew the hydraulic control unit was not the final repair, but I was optimistic. I will definitely keep everyone up to date.
    2015 Rt S Se
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    so what did they actually replace that made it better ? i always thought mine
    had a shift or 2 i didnt like each time up or down. i try to stay in the 3-3500
    range also. rode the dealers demo 16 rt and it was about the same. only thing i
    noticed was a softer ride in the front and better cornering, even with a stock sway bar. irv
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    Jul 2015
    Saratoga New York
    Quote Originally Posted by Joyce47 View Post
    They replaced the Hydraulic Control Unit Assembly. They did so because it had codes in memory (never had a service light), I didn't realize the shift quality was bad until I rode their 2016 demo. Now it is better most of the time, and awful some of the time. My opinion is debris in the system that occasionally restrict passages in the control unit. I don't think 1 or 2 shifts randomly is anything to be concerned about, unless they feel like you slam on the brakes then release with a loud metallic clunk in the middle.
    2015 Rt S Se
    There's another thread in here someplace, that is discussing shift quality also... After reading what the OP in that thread is saying: I'm left wondering if the throttle isn't getting "chopped" by the computer, when it's time for the shift to occur. Has your dealer looked at this possibility?
    Jul 2015
    Saratoga New York
    I too have started similar threads in the past. When I say slam on the brakes it is more like someone who has never driven a manual trans and doesn't know how to use a clutch. If I blip the throttle when it is acting up the shifts are smooth so it is definitely a timing issue, either electronic or hydraulic. Either way you are quite correct that data logging will be required to locate the issue, especially since it isn't presently setting any codes.
    2015 Rt S Se
