Results 1 to 9 of 9
    Active Member Justacruisin's Avatar
    Jan 2015
    Ft. Worth, Texas
    Default SPEAKERS-2014 ST-LIMITED
    Cannot hear the music with stock speakers.
    Is their any way to just change out the speakers without adding all the other stuff and get a better sound at 60-70 mph.
    Thank You,
    Justacruisin
    Default SPEAKERS
    Do you know what size they are ? ? ? ....... Mike
    Jul 2011
    Mitchell, Ontario, Canada
    The front speakers on a ST are the same speakers used on the rear of a RT. Yes they suck. I replaced mine with Pioneer speakers that worked great for a while and now suck too. The biggest problem in finding a speaker that will fit is the depth. Most replacement speakers are too deep and will have to be shimmed out.
    2018 F3 LIMITED
    Sep 2016
    Michigan
    what size pioneer did you use? In your opinion why do you think the speakers sounded good but later horrible?
    Sep 2016
    Alma,Arkansas
    Default Speakers
    I do not use the radio while I am riding, it is my time, but could you add bluetooth speakers and run the sound into the helmet?
    Good Luck
    Greenville Tx
    A large windshield made the sound better for me. The wind had a big effect on the sound.
    2017 F3 Limited
    Jul 2011
    Quote Originally Posted by Biga48197 View Post
    Not sure why they went bad. But cannot run any base at all anymore because of the distortion.
    2018 F3 LIMITED
    Active Member wd8ajj's Avatar
    Jul 2014
    Las Cruces NM
    Sounds like they are not waterproof that will destroy a speaker in no time flat. Auto speakers are NOT waterproof, they are treated with a minor coating to make them somewhat water resistant but rain and dew will destroy them. Need to make sure there rated as waterproof or marine accepted. Any others will not last.
    I installed sound systems in autos years ago and would run into this many times. So if there not marked as Marine approved or waterproof there NOT.
    Feb 2016
    HAWTHORNE nj
    Default Question
    What was the size of the speakers....
