Trunk Liners
Has anyone use the Hopnel trunk liners and side bag liners sold on Amazon verses the Brp ones? It states that the least expensive Hopnel don't fit a 2016?
I have all 5 bags for my 2015 RT-S. They will fit the 16's. The RT has not changed. They are great for the money you spend. They are not rigid bags thou. But are good quality.
+1!
otherwise be a vulgar brawl.
Cognac 2014 RT-S
I have both the BRP and the Hopnel liners. Although both work just fine, if I had to choose one over the other I'd pick the Hopnel ones, because I think they're a better value.
MEP
2019 F3 Limited
I bought the Hopnel set, but the shoulder strap on the liner for the frunk tore loose after the second use. I'm sure I packed it too full, but it still fit in the frunk. Bought a semi rigid frunk bag to replace the Hopnel, and I love it.
Sent from my SM-N910V using Tapatalk
I use the Hopnel bags and they are a lot of bang for the buck. My only gripe is the one that goes in the frunk pulls off the weather seal every time it comes out. I have a gasket coming from Spiderpops that should cure that.
liners
I just opened ny new fronk liner today - from Hopnel. Nice. Quality etc, and of course price. All nice
side bags
Originally Posted by _..stiffler..
I have all the hard can am RT bags. 2 side ones and Frunk one with wheels and pull out handle and rear truck one. I'll probably sell. I bought an F3 so no need for them.
They are all brand new as well.
Sent on Note 5 in Taptalk
how much do you want for the side bags?
That's a problem I found with my Hopnel frunk bag the first time I used it; stuff settled and caused the lower portion of the bag to catch the gasket. My solution was to pack the bag with the heavy stuff on the bottom and not to overpack it which is easy to do IMO. Overpacking can tempt one to have to push the frunk lid down onto the latch thereby potentially causing problems releasing the latch. The bag hasn't caught the gasket since.
Cognac 2014 RT-S
Mehh, small duffle bags are a lot cheaper. Never really understood the whole liner idea myself. I pack certain things that I may or may not need, and then I can grab what I need, when I need it, without getting all of it...Just my thoughts though
2021 RT Limited
