Honda Exhaust Gaskets
2012 RSS SE5 25000 miles. Was getting extra heat on left side foot and lower leg. Replaced Y gaskets with Honda Gaskets. Right side was in great shape and left was about 60 per cent good. Muffler gasket was shot-used aluminum exhaust tape to seal it until new one arrives. Runs quieter and smoother now without the left side heat. I put anti-seize on the new gaskets to help it all slide together better. Started it up to check for leaks and in a minute or two the right side started to smoke like hell followed by the left side a minute later. Thought it was on fire as the anti seize burned out. Test rode and all is good now. Might want to skip the anti-seize. Thanks to Wacky Dan for his How to pics on this installation. Nice. John
ANTI-SIEZE
. If you used the Silver stuff ...that will burn .....the Copper color is for High heat ........Mike
Hi spyderwing,
Re: Was getting extra heat on left side foot and lower leg.
This started Thursday on my '08 with 11k miles. She is in for a new 'Y' gasket as I type this.
Jerry Baumchen
HONDA GASKETS
Originally Posted by JerryB
Hi spyderwing,
Jerry Baumchen
................Jer, I hope you brought them your own because otherwise they will use OEM gaskets and they SU*K .....
Mite want to do research on the anti seize some will hurt the O2 sensors
O 2 sensors
They are before the Gaskets in questions .......Mike
Hi Mike,
Re: OEM gaskets and they SU*K .....
In a few days I am heading out on a couple of rides & and a 2,000 mile trip. I'm taking what he has in stock.
I can deal with different/better gaskets when I have the luxury of more time.
But, thank you for your concern,
Jerry Baumchen
PS) Since you also live in the 'northern belt' of the country, you must understand that I want to ride every day that I can. Gaskets can be replaced during the rainy season.
