Results 1 to 14 of 14
Thread: drag bar on f3s
    Canada
    Default drag bar on f3s
    Hi i just got my f3s today
    and i had install the brp drag bar on it.
    And i find out that the left switch box is touching the fuel tank cover while i turn fully left.
    Is there any thing i can adjust?
    thank you
    on getting your bike; even if I don't have any advice for you!
    Apr 2011
    GREENVILLE, SC
    Default 1st THOUGHT
    THAT WAS THE 1st THINK I THOUGH WHEN I SAW THEM.......
    not a good situation...
    you may need to adjust it back to the OEM that came with it...
    on your selection of the F3.... you will love it....
    SPYD3R
    NorCal - Northbay
    Quote Originally Posted by SPYD3R View Post
    SPYD3R
    Nope, something is wrong with the install or the components themselves are damaged or have the locating pin drilled incorrectly or something. I have the drag bar and zero interference issues.....
    Chuck
    Canada
    i like the f3. its fun.
    i may try to reinstall the drag bar today and find out the reason.
    Another problem.
    Do you know how to adjust the brake pedal ?
    Its 45 ° .can i adjust it to 30°?
    i try to play with the rod near the brake master cyclinder.
    this move did make the brake pedal lower.
    but the brake light will stay on and the brake pedal got a lot of gap after that.
    Very Active Member Ron2andia's Avatar
    Jun 2012
    Phila
    Live, Love, and Ride! God Bless!
    Nov 2013
    Oro Valley Arizona
    OK I will bite. What's a drag bar? Does it have another name? To me a Drag Bar is an extension out the
    rear with small wheels to prevent a backward Cranial Perch! Prevent front tire/tires from rising up.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Default Welcome welcome....
    Does seem to be a problem with the installation or the parts. If all was done correctly seems the only thing is to raise the base so the bars clear . They should clear. Some mounting systems have two different size plates they may be inverted just guessing don't know this system....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Canada
    Quote Originally Posted by jaherbst View Post
    Jack
    it is the brp made ufit system handle bar.
    i cant remeber the parts number.
    Harrington, Australia
    Quote Originally Posted by GDA View Post
    I tried the same thing, GDA, with the same result. I gave up moved the brake back to where it was. I tried a few other alternatives, but none were successful. My solution came from Lamonster's RIP floor boards, which change your foot position in relation to the pedal. They are just brilliant, and for me, well worth the price. I can't tell you if they are an option on the F3S, though.
    Peye
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member monkeyboymorton's Avatar
    Sep 2015
    UK
    Try slackening off the bolts that clamp the bar to the steering column and rotating the bar upwards. Assuming it's the same as the standard bars it has a fair bit of rotation in that clamp.
    I adjusted my standard bars recently to avoid the 'hands in the mirrors' problem. After lowering the bars my left control was just catching the tank. I then adjusted it up a tiny bit so it didn't catch any more. You shouldn't need to take the whole thing off to stop it catching.
    | 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
    Canada
    Peye
    Hi i try the drill hole mod today.
    it work but you will have to brake a bit hard to stop the bike.
    thank you
    Canada
    Quote Originally Posted by monkeyboymorton View Post
    will try this tmr. thank you very much.
    Default Well....
    Jack
    I think we know them as "Flat bars". Just a straight across no bend handlebars....Have often wondered myself why they call them drag bars cause most drag bikes don't use them....
    ​2012 RS sm5
