My question is how will the amp be connected to the radio on a 2016?
Rick
Rick
The wires supplying signal are already under the back seat from what I can see. Will have to wait and see if that is the case...
Regards, Rodney
2011 RT-S SE5
2016 F3T SM6
I believe that's only on the 2017 model???
No, they are under my 2016 seat.
Regards, Rodney
2011 RT-S SE5
2016 F3T SM6
Originally Posted by RotaxDuramax
This may be very well in my future to add to the triple black. Also hope the auto level air will also be retrofit able to the 16's as well, getting tired of always having to bring along a battery powered compressor to adjust being single rider to two up riding on the fly.
"Battery powered compressor"? I kept the tiny hand pump from the Vision. It's about 8" x 1" and includes a gauge. It only takes about 20 pumps to move from 45 to 60 psi. I actually used it to pump the shock from 0 to 45 at dealer pickup, and it was pretty effortless.
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
So you are saying that the audio connection from amplifier to the radio already installed on the 2016 F3 L?
and are they available online?
I have a F3T but yes, it appears all the wiring for the top case is there. Aux power, lighting, and audio. I'm just guessing as they aren't labeled but all the plugs are there capped and ready to get plugged into. If you do a build and price on a 16 F3T or F3L you will see the top case as an option so I'm thinking they are be prepped for them. Unfortunately, the only thing under the back seat that is labeled is the accessory power so I can't tell what's what for sure. I'm sure a dealer can confirm. Then again, they might confirm that all those plugs and connections are for something entirely different. I'm just guessing and hoping. I could be completely wrong. It's happened a time or two before...
Regards, Rodney
2011 RT-S SE5
2016 F3T SM6
It's on page 71 in the 2017 Catalogue:
http://www.publications.brp.com/doc/...og/2016080803/
Neil
2020 Harley Davidson Tri Glide Ultra
2017 F3-T SE6 White / BRP Backrest / Nuvi 58 LM / Polaris Spring Spacers / CALSCI 22" Shield
I'll post a pic, Bob, but it wasn't an ad for the Victory pump per se, but simply to note that a miniature hand pump works.....
HeliBars Handlebars
Kenda Kanine rear.
Handpump
The Vision pump looks very similar to this, Bob......Victory charge like Can Am so it would probably be $200 from them. This one is $70 and you can get cheaper ones depending on how often you think you would use it.
http://www.pushys.com.au/topeak-pock...FQt_vQodkL8IHQ
HeliBars Handlebars
Kenda Kanine rear.
I can't see the plugs shown in Lamont's Spyder trunk removal video under the rear seat of my F3-L, but I also can't remove the rear cowl easily as I have the fixed BRP backrest. My guess would be that they are under that rear cowl, if anywhere, as people would rarely take the rear cowl off, so BRP could keep their "little secret" pretty much under wraps until the 2017 was released.
The fact that BRP say it "fits the 2016" does tend to indicate that the wiring is already in place, but.........
HeliBars Handlebars
Kenda Kanine rear.
We'll have to see Pete and you certainly could be correct...
Regards, Rodney
2011 RT-S SE5
2016 F3T SM6
Sorry for reviving an old thread.
I have recently bought my first , a 2017 F3 Limited and would like to know how I can get the part number for the plastic cover so I can take the top box off? I only need the top box on for when I go on long road trips and overnighters. I spend a lot of time just riding the local back roads and really like the bagger look for when I just want to cruise the beaches.
